Brembo Hoses and Reflash?
I have a 2008 HHR SS That I have all the part except the brake hoses to do the swap. Anyone know where to get a good deal on braided steel?
Also I have a automatic that could use a little more power... Whats good? Peace y'all |
Welcome to the site jczboy. I switched to Brembos and just used the same brake lines works just fine. Trifecta will give you around 300 hp.:thumb:
Sweet! Did you use the same banjo bolts too?
Thanks |
So... I ended up with some new red (Power coated) Brembo's Cost was $400
Drilled and slotted rotors with pads and hardware $180 If you bend the brake hose slightly at the bracket, the stock hoses work great along with stock banjo bolts... Total cost was only $580 |
Great, you saved enough to buy a tune, so you will need the extra brakes.....:twothumbs:
Got the tune first.... That's when i desided i NEEDED the brakes... now my neck breaks both ways :)
I was pretty surprised how much more brake power the Brembo's give you. No problem slowing from over 100 now. ...:twothumbs:
The Brembos always look good when they're new, clean and freshly painted.
(before the brake dust attacks them :lol:) Attachment 14659 |
Still adding stainless braided brake hoses would be the ultimate ticket..
SS brake line would be great... Working on lighting next... Got Depo's in the mail along with some HID's... I may take apart the old ones making them into projectors with halos
