Chevy HHR Network
-   Brakes | Suspension | Shocks | Struts (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/)
-   -   Clanking noise from front wheel area (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/clanking-noise-front-wheel-area-50518/)
hhrumadbruh May 11, 2014 06:41 AM
It only happens when I'm stopping or starting.
I had a bad experience with firestone and I had(have) slight wheel wobble at about 55mph that firestone is apparently unable to fix (or un-willing) and now I assume the tie rods have come loose.
It's a fairly high pitched clinging sound that is somewhat nerve wrecking.
Is there anything I can look for that would be loose that is easily accessible?
Oldblue May 11, 2014 07:41 AM
tie rods as mentioned, sway bar end links, sway bar bushings, lower control arm rear bushings, bearing hub just to name a few but most common sources of clanking noises
firemangeorge May 11, 2014 09:18 AM
"high pitched clinging sound" ?
Sorry. Not sure what clinging means.
whopper May 11, 2014 10:47 AM
Have you not tried the Search Tool at the top of the page? Give it a go - it works.
donbrew May 11, 2014 04:14 PM
I recently stumbled upon a factoid about the clunk. It seems that if you reuse the axle nut after removing it it can cause a clunk.
I believe there is a TSB about adding a thrust washer to the inner side of the hubs.
My 2008 did it my 2011 does it. I don't care.
Have you ever thought about the hubs?
Why do you think tie rod ends would have become loose? They are either attached or not attached, they do not have a nut like old times.
Why go back to a shop that you don't trust? There have to be hundreds of other places around you.
ChevroletCustomerService May 11, 2014 05:47 PM
Hi hhrumadbruh,
I’m sorry to hear of the clanking noises you are experiencing with your HHR. I cannot guarantee anything, but I will be glad to look further into this for you. Please send us a private message referencing this thread if we can be of any assistance. Thank you.
Kristen A.
Chevrolet Customer Care
