Chevy HHR Network
-   Brakes | Suspension | Shocks | Struts (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/)
-   -   Cobalt rear brakes on HHR (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/cobalt-rear-brakes-hhr-23020/)
gimpy Apr 13, 2009 11:34 AM
Has anyone explored fitting the Cobalt rear discs to the HHR to give it discs on all 4 corners.
Maybe it's athought for vendors!
Gimpy
09 Panel Apr 13, 2009 11:50 AM
Do a search, it's been done by someone here.
masterchief1112 Apr 13, 2009 01:13 PM
Search function is your friend. here ya go disc brakes. if you could find a wrecked cobalt ss you could essentially pull the entire rear end off of that and transplant that onto the HHR.
hvrod Apr 13, 2009 01:20 PM
Basically everthing bolts/fits up..
I did braided brake lines, so I had to clamp, use supportive brake fittings
to mate with existing line on car...
You will also need the emergency brake cables from the SS..
garagebuilt Apr 13, 2009 03:31 PM
do you just pull the bolts on the back side and take the whole drum assy. off?
hvrod Apr 13, 2009 03:42 PM
You need to purchase the rear axle SS unit too..
It has the welded plates/brackets that has the mountings for the
rear disc brake calipers...
http://i37.photobucket.com/albums/e7...DSCF3189-1.jpg
gimpy Apr 16, 2009 10:02 AM
Cobalt rear brakes
Thanks for the replys. I don't have an HHR yet & wanted to find out so I could convert after I get mine. After yrs of 4 wheel discs (mustangs,Porsche, SHO, etc) I'm spoiled!
be back after I'm offically an owner.
Gimpy
