Cold weather sqeaking is back...
I had a '96 Z28 that started doing this back in '06. The rear would squeak or creak when going over bumps, but only in the cold. It eventually progressed to where all four wheels would squeak at any temperature, more or less. I was also told that lubricating bushings would fix this, but I was never able to solve it...
My 2009 HHR with 10000km has the same Problem...it is my first car that make soo bad noises (only when it ist cold Winter Time) at summer no Problems ...but we have not so much bumbs here (Baden-Wuertenberg Germany Stuttgart) When I hear it the first time I think my car break down
On regular streets I have no problems with it you hear nothing
Michael
Michael
I agree with everyone on here that the sway bushings can cause this problem. I had that as an issue but it was more a clunk than a squeek. I also had a squeek issue. My dealer figureed out that the squeek was coming from the recirculating door flap. It had broken and anytime there was a pressure gradiant in the cabin (ie door shutting, breaking, accelerating and going over bumps) it sqeeked. They fixed it and there has been no squeek since. I dont know if this is what you guys are noticing, however, if you have tried everything else and it hasnt worked, why not ask them to check the recirculating door flap.
Where can you get these greasable ones? Anyone have a link to a site to order some?
I also remember working on some older vehicles (high mileage, not HHRs) and found that repairing vehicles the "squeek" (not thumping) was the factory sealed ball joints having grease cake in them due to the ice cold weather. All you needed was a buddy to push up and down on your bumper while you had you head behind the front wheel. Disclaimer: Do Not hop up and down on your HHR bumpers-I did that when "dey made dem cars out o steel"-see old delta 88 in my pics. Solved those problems by replacing the ball joints. Of course old school cheap fix was a needle injector for the grease gun to use in the joint boot, or if you tapped and installed grease fittings. Ahhhhh-my younger days when I was called McGyver
