Chevy HHR Network
-   Brakes | Suspension | Shocks | Struts (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/)
-   -   Front brakes (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/front-brakes-44845/)
sleeper Feb 14, 2013 12:26 AM
Originally Posted by chefan (Post 692260)
thanx man:)kinda old school n the brakes were a little different than i remember.wow
:thumb: I think newer brakes are easier to service.. Believe me I'm old school too man..
Grizzly old man Feb 14, 2013 01:22 AM
I was having some problems with my front end. I went through a lot of grief because I did not think the front struts were bad.
I replaced a lot of parts that were fine before I finally broke down and put in the new struts. In the process I ended up with a lot of new parts that can be greased now.
Last summer when I decided to replace the front breaks the disks would not let go. Normally you hit them a mighty smeg with a 2 pound hammer and they come ringing off the front hub. That's what has almost always happened on all the cars I have done front disk breaks on.
Not this time buddy, I had to put a crows foot pry bar behind it and beat both disks all the way off.
Good luck I really hope the single hit with a BFH works for you.
sleeper Feb 19, 2013 09:53 PM
I'd be a bit cautious with that BFH, the wheel bearings are not like the old tapered Timkens..
hurst2001 Feb 20, 2013 08:21 PM
If it helps go with wagner thermal quit front pads and new rotors,i went with bendix semi metallic and they squeak at low speed ,i even put the stop squeal on the back of pad a little better but still there when brakes are use more ..with the wagners no squeal at all.... :twothumbs:
