Front & Rear Suspension Refresh - Parts List?
So the suspension on my new-to-me Misty Jewel is definitely loosy-goosy. Since I picked it up so cheap, I have the funds to go ahead and fully refresh the front and rear suspension, and even upgrade it a bit.
I've done my fair share of searching in the forum, and I've been able to pick up things in bits 'n bobs, but my goal is to try and consolidate everything I need into one thread. So here's what I've been able to figure out that I need so far:
Front
Struts - Monroe Quick Struts / Complete Struts or similar
Lower Control Arm Assembly (Aluminum) - MOOG - RK620897 / RK620898
Sway Bar End Links - MOOG - K750012
Sway Bar Bushings - Energy Suspension - 9.5159
Rear
Shocks - Monroe, KYB or other
Rear Sway Bar - TTR
Is there anything I've missed, or do you have other suggestions for manufactures/suppliers?
Thanks!
Front
Rear
Rear Sway Bar - TTR
Thanks!
Last edited by Nodaclu; Aug 16, 2018 at 10:24 AM. Reason: Updating part #'s for accuracy
You could go to this sites Common Used Parts lists ( a quick look over of your list shows some numbers don't match)
LINK: https://www.chevyhhr.net/forums/comm...-thread-48833/
P.S. Your post doesn't say what year or model your HHR is. There are some differences. Especially swaybar bushings in the early 2006's.
Thanks Oldblue!
Whoops! 07 2.2 LT. I checked out the Common Used Parts lists, and I've edited my original post as a result.
My HHR has 107K on the clock, and it's a lifelong CA desert car, so there shouldn't be any rust or corrosion issues to worry about. I'm hoping this all goes smoothly as a result.
I really want to refresh as much as I'm able while I'm in there. Been wrenching on cars for 33 years now, and it just ain't as much fun as it used to be...lol.
