FYI Lowered w/ aftermarket struts
Found out over this weekend that if you changed out your struts and are lowered,,AND need to use camber bolts, that some of the struts are NOT set up for this like the stock units are. The stockers are slotted while the aftermarket ones are straight drilled..so if you have replaced struts and the alignment guy says he has to grind out the strut to get back in alignment, you now know why....
