Heavy Jobs With A Lowered HHR?
The point is...once you start on the suspension, it is hard to stop. My suggestion is Eibach pro kit. I have twenties, with 100lbs of stereo in the back. Never a problem, add a few people in the rear..could be a problem. But if you stick with 18's... you are good to go brother. The difference between the twenties with the Toyo tires and the lowering..well.. it is a different car. It may not be the fastest, but it will corner really nice! Todd (Uma)
Only dumb question is the one not asked.
Here's a post for some light reading..........
https://www.chevyhhr.net/forums/show...1&postcount=29
well... the Eibach springs... do they have a high spring rate and stiffness? I know my equipment is at least 300 lbs. I want that low ride... but I gotta cart this stuff around still. ugh...
