Ksport Coilovers
Old 04-02-2014, 06:47 PM
mississippisunburst's Avatar
Ksport Coilovers
Pulled the trigger today on Ksport coilovers
mississippisunburst is offline
Old 04-03-2014, 07:25 AM
Nice, post some pics when you install them!!
Oldblue is offline
Old 04-03-2014, 12:23 PM
chefhhr's Avatar
If they haven't shipped I'd recommend going with BC, KWs, or Stance. I've got Ksports and the rears are a pain to adjust once they are on the car. The damper control is actually built into the shock so you have to remove the shock to change the damper. Hope you get it right before you install!
chefhhr is offline
Old 04-06-2014, 08:37 PM
How do you have yours adjusted?
Old 04-07-2014, 03:21 PM
chefhhr's Avatar
I've got mine about 3 clicks away from the stiffest setting up front and about 4 from the softest out back. When I'm feeling froggy and have some time to kill...I'm going to readjust the rears a few more clicks stiffer. I'm getting used to the ride now...it's actually not that bad. I have the lock rings completely removed in the rear so it's sitting as low as possible out back...up front I have it about an inch from the lowest it'll go. Here's how she sits...
This was taking right after my last adjustment...my handles have since been swapped out to match the color of the car.
chefhhr is offline
Old 04-07-2014, 06:27 PM
Nice Stance, I'll attempt similar adjustment to start. thanks
Old 04-08-2014, 08:48 AM
nice stance, indeed!! the worms are wearing hardhats!!!!
Oldblue is offline
Old 04-18-2014, 05:32 PM
Box arrived today. Install begins after 4 work days. Looking forward to Showfest in May.
Old 04-19-2014, 09:09 PM
chefhhr's Avatar
Readjusted my rear damper...10 clicks from stiffest...feels a lot better.
chefhhr is offline
Old 04-23-2014, 06:29 PM
Installed today. Adjusting tomorrow. Got it way low in the front. Pictures when I get it right.
Quick Reply: Ksport Coilovers
