HHR SS 10.6” solid rotor
Cobalt SS 11.5” vented rotor you will need caliper brackets and calipers https://www.rockauto.com/en/catalog/...b,caliper,1704 |
But Barney won't need calipers and brackets, as he is installing them on his SS.
Bigger diameter rotors will need bigger brackets.
The same thing applies if the rotors are thicker. He will need calipers with a wider spread than the stock HHR ones. |
Wasn't there some one here who tried to do autocross with an HHR and was told that the CG was too high and would not allow that vehicle to compete.
Some governing bodies allow it, some don't. I looked into it, 2 clubs in my area, 1 allowed PT Cruiser, but not HHR.
(Post 939622)
It’s like the upgrade to larger diameter SS non Brembo front brakes on an LS/LT
Will the HHR SS E break cables hook up to the Cobalt SS calipers ?
This was in the "related topics" right below the quick reply window. https://www.chevyhhr.net/forums/brak...kes-hhr-23020/
They are different part numbers however that could be for length. The ends appear to be the same
| All times are GMT -5. The time now is 03:20 AM. |
