How I solved "warped rotor", it's the bushing!
Old Nov 5, 2011 | 02:01 PM
Talking How I solved "warped rotor", it's the bushing!
Turned out to be the rear vertical mounted control arm bushing was bad. Mine was on the right side. They are difficult to inspect, you need to get the car up on a lift and put a bright light on the bushing to see it. Don't let the shop tell you there are no after market parts!!!!!!!
The easiest solution is a new control arm Dorman 521-025 (L) & 521-026 (R) for FE1 and there are a couple of other mfgs, they include new bushings and ball joint RockAuto and EBay around $68 + shipping. R & R is a matter of 4 bolts. You will need a torque wrench for install. 1 hour per side including jacking it up.
You do need to be careful when ordering, the parts listed for "FE1" are for Cobalts that have a powder coated steel control arm V. HHR control arms are cast and don't seem to be listed by package, except I did see 1 mfg advertising "new" FE3 for alot more $.
geg
Nov 25, 2020 12:52 AM
zuni
Aug 15, 2014 08:13 PM
donbrew
Apr 23, 2013 09:09 AM
OldSchool57
18
May 1, 2012 02:33 PM
mikiec
Oct 9, 2007 01:50 PM
