Inner Tie Rods
Bringing it back again. I just did mine. One of the joints, whether the ball or socket failed, I don't know, hung limply with the outer rod end removed.
You will probably render the factory clamp on the rubber boot on the rack useless when taking it off. I used a large zip tie to replace the metal clamp on mine. The small spring steel clamp on the outside is reusable.
ColeTrickle
Jan 12, 2019 12:10 PM
hhrlover101
Sep 6, 2012 06:06 PM
