Installed TTR Sway Bar
#71
Dead thread but relavent; I just installed mybar but didnt use loctite. I bought it but was so excited to get the bar on that I forgot to put loctite on. Is it really necessary to use the loctite?
#72
No it is not needed if properly torqued. To be safe I would check torque again on the 4 bolts after 100 miles.
#75
If you're going to check the torque after 100 miles, why not just pull the bolts and add some Locktite while you're under there ?
Just pull 1 bolt at a time and you won't have to remove the sway bar.
#79
From their website.
The rear sway bar for the Chevrolet Cobalt/HHR 2005-11 (Also fits all "SS" models) Saturn Redline/Ion 2004-10 comes standard powder coated in Red or Black. Other colors are avaliable for a small upgrade charge.
