Koni struts and rear shocks
i got the koni struts and koni rear shocks all installed all i can say is very nice,with the lowering springs and ttr rear sway bar my car handles ten times better than i thought it would. thank you aaron (turbotech)
Im interested in the koni struts and rear shocks, suggestions on settings.
I just recieved my GoldLine springs and would like to replace the struts while I have it apart.
While Im under the car I will be replacing the sway bar bushings, end links, and looking for anything that might need attention.
Will also be adding the ttr rear sway bar.
Any suggestions on things I should check.
