Koni Struts IN STOCK!!!
KW uses Koni Struts on their coil overs, so you know they are good.
Rear Konis are full replacement.
Front Konis are inserts (like most all applications they make). You use the stock strut sleeve to house the Koni strut in. Very easy to install as it comes with instructions :)
The rears are 100% direct replacement, the fronts are simple, you remove the stock strut, cut/saw it at the tube, and insert the front koni strut inside the old strut housing. 1000's have done it. Very simple.
2LT struts to these dont even comprare, Konis are 10X better.
