Ksport Coilovers
Old Apr 24, 2014 | 11:47 AM
mississippisunburst's Avatar
After a couple of attempts, I'm going to try this.
Old Apr 24, 2014 | 11:50 AM
Now that looks great. How's it riding for you?
Old Apr 24, 2014 | 12:06 PM
skyline26's Avatar
sexy!
hows the ride?? (for both chef and mississipi)
what settings are you on?
Old Apr 24, 2014 | 03:20 PM
Still Looking for Damping Adjustment to my liking. Started halfway and will be going softer from there. Not a dd, so it will take some time.
Old Apr 24, 2014 | 07:01 PM
chefhhr's Avatar
Looks great! The ride for me is great now that I've got it dialed in...I'm at full stiff up front...10 clicks from full stiff in the rear.
Old May 2, 2014 | 06:02 PM
All aligned within specs (required camber bolts) and tires balanced. She's a rollerskate now.
Old May 10, 2014 | 06:42 PM
Next up,,,, 14.5" Drilled and Slotted rotors, 4 piston Brembo calipers, and steel braided brake lines.....
Old May 10, 2014 | 10:42 PM
Curious here. Will the 14.5" rotors and Brembos clear the stock SS rims?
I wouldn't think so.
Old May 11, 2014 | 07:46 AM
ZZ Performance says:
Looking for big brake upgrade? This is a 14.5" front brake upgrade kit that uses a genuine Brembo 4 piston caliper.
This will fit perfectly behind factory LNF wheels that are setup for the factory Brembo brake option.
To run this kit on a factory non Brembo caliper wheel, you would need to replace your stock wheel studs with a set of ARP wheel studs, and install a 1/4" wheel spacer on each side.
We have not tested fitment on any other wheel.
Fits 5 lug Cobalt
Sold as a front kit.
Old May 11, 2014 | 08:08 AM
Thanks for the kit info !!
