Chevy HHR Network
-   Brakes | Suspension | Shocks | Struts (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/)
-   -   Lower Control Arm Bushing? (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/lower-control-arm-bushing-28595/)
oldford Mar 15, 2010 10:18 AM
My 2006 LT lower control arm is banging into the sway bar on rough roads. I can see the shiny spot where the contact is being made. I think the lower control arm bushings are worn out. Anyone have experience with the Mevotech lower control arms? Other thoughts? I've got new sway bar bushings and ends and struts all ready. 95k on it, all hard use, dirt and gravel roads, etc.
TIA, Eric
WillBeck_CobaltSS Mar 15, 2010 10:53 AM
link to the mevotech? good time to upgrade to FE5 components i think :)
oldford Mar 15, 2010 11:49 AM
Mevotech lower control arms are sold by Rock Auto and others, apparently the only aftermarket available. What's an FE5 upgrade entail? My glove box door carries an FE1 code.
Thanks, E
WillBeck_CobaltSS Apr 7, 2010 05:39 PM
The FE5 suspension is standard on the SS cobalts. Since we can share just about every other suspension component, why not control arms?
FE5 arms are made of aluminum, and are much better than the standard FE1 variety.
oneton Apr 7, 2010 06:00 PM
I was thinking FE5 was springs & shocks only
WillBeck_CobaltSS Apr 7, 2010 06:04 PM
Nope, FE5 includes the front swaybar, rear TWB, shocks/struts, springs, and control arms.
prod Apr 7, 2010 09:49 PM
I believe changing to the FE5 front swaybar also requires new bushings and clamps, and dropping the front subframe to install. It may require more, as I have heard FE1 swaybar clamps are secured with a bolt on one end and a tab on the other, while the FE5 clamps are bolts on both ends. Perhaps someone could verify that.
WillBeck_CobaltSS Apr 7, 2010 10:12 PM
some 06's and the 05's had a single bolt clamp. The extra torsion forces will eventually cause the clamp to fail. Later 06's and all following SS's had dual bolt clamps.
and yes, changing the bar requires new clamps and bushings, but it can be installed without dropping the sub-frame.
fringeIT Apr 8, 2010 06:55 AM
Which would be easier?
ZTony8 Apr 8, 2010 09:57 AM
The control arms are the same part numbers on the Cobalt and the HHR so swap away!
