Lower control arm rear bushing
Old Mar 8, 2024 | 05:05 PM
Mookie1's Avatar
Found some online.
Old Mar 8, 2024 | 05:39 PM
Another dead part number…… they are 14 mm x 2.0 x 131 mm
Old Mar 8, 2024 | 06:19 PM
But the tip has a special taper, making it easier to start threading.
Old Mar 8, 2024 | 07:32 PM
Mookie1's Avatar
Silly question but what about the cage nut. Is there a part number or just get a nut?
Old Mar 9, 2024 | 07:22 AM
In here
https://www.crateenginedepot.com/Nut...76-P53605.aspx
Old Mar 9, 2024 | 08:58 AM
Mookie1's Avatar
Thank you
I spent last night looking on the internet for them and couldn’t find them.
Old Mar 9, 2024 | 04:08 PM
Oldblue, do those need to be welded in place?
Old Mar 9, 2024 | 07:04 PM
lazaino's Avatar
They look like they should be spot welded with enough current to weld all 3 points at once.
Old Mar 9, 2024 | 07:46 PM
fastsuv's Avatar
You won't be able to spot weld them in. There's no room. They are probably spot welded at the factory before the other panels are welded in.
I just bought a M14 x 2.0 Metric Flanged Nut, Grade 10.9 (this is similar to a grade 8 SAE bolt). Then I held it with an offset box end wrench that I cut shorter to fit the area. I think it was a 22mm wrench. I broke the old cage nut loose from the welds using a screwdriver and hammer.
In your first post you mentioned the bolt was loose from the cage nut. Why do you need a new nut?
Steve
Old Mar 9, 2024 | 08:47 PM
PulpFriction's Avatar
Just what I was thinking. Flange nut. They don't take much to hold.
