Lower control arm rear bushing
You won't be able to spot weld them in. There's no room. They are probably spot welded at the factory before the other panels are welded in.
I just bought a M14 x 2.0 Metric Flanged Nut, Grade 10.9 (this is similar to a grade 8 SAE bolt). Then I held it with an offset box end wrench that I cut shorter to fit the area. I think it was a 22mm wrench. I broke the old cage nut loose from the welds using a screwdriver and hammer.
In your first post you mentioned the bolt was loose from the cage nut. Why do you need a new nut?
Steve
Steve
