Lower control arm rear bushing
If you wanted to go through the effort you could drop the the cradle to get to the captured nut and tack weld it. I don't think I would use a nylon nut. Try to get the nut and bolt be close on the Galvanic scale to avoid corrosion. Maybe some ant-seize or dielectric grease would help the next guy.
You would not want a loose fit in the bushing sleeve, that would defeat the purpose. Needs to be a tight clearance fit, almost interference.
Dropping the cradle doesn’t give enough room on the driver’s side to get a MIG wand into weld the cage.
The idea of a large piece of metal with threads and resistance against the length of the piece to hold it from spinning, I don’t know why they wouldn’t have done this in the first place.
FirstGenHHR06
Maintenance and Upkeep
20
Jul 24, 2023 09:36 PM
stidge77
Apr 10, 2019 01:34 PM
alexrckid
11
Feb 26, 2012 07:46 PM
