LS Front Warped Rotors
Old May 12, 2018 | 03:49 AM
User Omega's Avatar
I know that the brakes on the HHR base model were undersized. Ive read a ton of threads and posts talking about it. Most say to slow the heck down and you won't have that problem but I want to beat on it a bit without dumping $600 into a set of brembo brakes. Are there any stock diameter rotors that are less likely to warp or is it just a game we all have to play until we upgrade?
Old May 12, 2018 | 06:10 AM
Top of the line NAPA work for me...
Also you have to keep the rear brakes adjusted properly. (they don't seem to "self-adjust" as they should.)
Old May 12, 2018 | 08:29 AM
J W Davis's Avatar
100% agree here, I have all original bakes (except pads) Napa parts are always the best for me.
Old May 12, 2018 | 08:34 AM
Or upgrade your LS brakes for the Non Brembo SS front rotors and keep your rear drums adjusted as Donbrew pointed out
Here’s an excellent how to....
https://www.chevyhhr.net/forums/brak...ard-hhr-42938/
Thanks Solman98
Old May 12, 2018 | 09:02 AM
I guess you just never read the threads on this forum!
Our advice has always been to be sure the rear drums are manually adjusted properly. I have NEVER seen a post advising "slow down".
Buying slotted or drilled rotors is a waste, unless you are doing for looks.
Mostly, the rotors are not warped. LCAs, bearings, struts are bigger offenders.
Old May 12, 2018 | 10:38 PM
I check my rear brake shoe adjustment, at my annual oil changes & service.
If your E-Brake is adjusted properly, you can tell if the rear brakes need an adjustment, by just counting the clicks it takes to hold the car on a slight slope in neutral.
For my ride 3-4 clicks & I know I'm still good.
My 2LT Panel came with non-Brembo SS front rotors, but same calipers, which has a bigger piston that the SS has.
Old May 12, 2018 | 10:45 PM
My brake shake at highway speeds turned out to be several things, the intermediate steering shaft, the steering rack input shaft bushings were worn and the upper engine mount was toast! Check the rear LCA bushings too!
Old May 12, 2018 | 11:01 PM
User Omega's Avatar
As stated, I have no issue reading threads. Heaps of them that are mostly filled with garbage from people who I am not sure have even seen a hand tool (I am definitely not used to that on a forum). I do have an issue searching this forum. The information is scattered, the search bar is poorly coded and google is only so much help since it's not a super active group here. I have been using multiple forums for more than 10 years and am a staple on other pages for tech info. There isn't much that I cannot tell you about a GM F or Y body car (I don't know it all and still learn things from others weekly. I am not afraid to admit when I do not know). I do not have the patience to search for hours through useless threads when I can come here and get helpful advice as seen above. Maybe I'm getting a glimpse into why the place is not a rage when there are a ton of these cars out there.
Back on topic:
Interesting info on the other hard parts being big offenders. I am curious if you could provide details on how those components cause rotors to warp. That is the solution to a vibration while braking. The G6 base was plagued with the issue as well. I am by no means saying the other parts are not common failure points as I know they are. Just wondering how they are contributing to the undersized braking system issues.
I am really not into making the thing look cool. I am just into improving the reliability and extending service intervals on things. I have motorcycles and racecars for the flash and dash. This is an anemic 4 ticker that will be used as a work transport and nothing more. I only work 3 days a week but work is 120 mi/day.
Tech Tip to avoid getting out tools and making manual adjustments to rear brakes:
Knowing how the "automatic" adjusters work in these cars, I am going to go out on a limb here and say that they aren't staying in adjustment because they are adjusted up with the parking brake. If one has an automatic transmission it is very likely that they would never use it. Thus causing the adjuster to not take up. A simple solution to that problem is to run the parking brake a few cycles a month. Chrysler cars were notorious for this as well.**
**The adjuster can get gummed up with dust but its fairly rare. Commonly this happens when a brake isn't adjusted for some time or when the adjusters aren't replaced/cleaned with the shoe R&R.
Thanks Solman98
Very helpful post. I hadn't even considered a factory option upgrade. Thank you!
Old May 13, 2018 | 04:06 PM
What they are saying is that brake shake is NOT always warped rotors. Check Oldblue's post #7
Old May 13, 2018 | 04:45 PM
Thank you for the schooling.
