Maybe helpful for front control arm rear bushings…
Old Dec 31, 2024 | 05:03 PM
Gearhead1's Avatar
I have changed many of these over the years on many types of cars. Always dreaded it cause if they are hard to press in the outter shell can swell and they are ruined.
Recently I put some in my wife’s car (jetta but same, same) except I cut about 3” off bottom of aluminum can and put a small candle under it to heat it….and melted paraffin wax. I used an acid brush to coat the control arm bores and the bushing outer shells. Use a small hammer to get them started in straight….both went in the easiest I have ever done.
Hopefully be of help to someone else
Old Jan 1, 2025 | 05:36 AM
A great tip! Thanks.
Old Jan 1, 2025 | 09:24 AM
When GM says "press the bushing" They do not mean a hydraulic press. This is a bushing press:
Old Mar 1, 2025 | 08:15 AM
I found this kit
https://www.vevor.ca/socket-wrenches...p_010202637286
A review video
ENASNI TILLER
Maintenance and Upkeep
31
Mar 22, 2024 07:33 AM
alexrckid
11
Feb 26, 2012 07:46 PM
hhrfreek
Nov 24, 2011 02:19 PM
bigw10921
Jul 17, 2010 10:35 AM
