need some info
Old Oct 2, 2006 | 07:15 PM
ny5112's Avatar
need some info
how was wondering does anybody know if they are gonna come out with some coilovers for the hhr if so what company also any word yet on the silverstarrs for the hhr also one more thing how many inches are the fog lights that will fit very well no gaps any help will be nice thank u fellow hhr drivers from nyc
Old Oct 2, 2006 | 07:33 PM
Angelo's Avatar
Will lowering springs not do the trick for you ? Here is the info requested on coilovers.http://www.autoanything.com/suspensi...0A2490643.aspx
Old Oct 2, 2006 | 08:54 PM
Sonoma GT's Avatar
I was wondering this also. Iwould like to add fog lights that fit like stock.
Old Oct 2, 2006 | 10:15 PM
oneton's Avatar
why not just get OEM lights ? just buy the lights and switch. fog lamps are $56.25 ea. come with bulb everything just snap in. switch is $20.00 just plug in. will need a harness to fog lamps there is a thread on how to make one here. thats how I did mine. then you can adjust them they have alinement just like a head light Then it is all oem & GM.
Old Oct 2, 2006 | 10:21 PM
Angelo's Avatar
Cheap enough, much better than aftermarket on that
Flyboy6257's Avatar
Then if you want just change ou the bulb to whatever color you want. I think its a H4 bulb. Thats what I did with mine
Old Oct 2, 2006 | 10:23 PM
oneton's Avatar
on the silverstars bulbs H13ST $19.95 at auto zone silverstars also for fog lamps I have them in now like them a lot very clear for a old,fat blind guyat night. looking for fog lamp # 9145ST you will need them
Old Oct 2, 2006 | 10:32 PM
oneton's Avatar
parts and price from http://www.gmpartscheap.com/ $48.12 cost plus 10%
Old Oct 3, 2006 | 12:12 AM
SoCalHHR's Avatar
how was wondering does anybody know if they are gonna come out with some coilovers for the hhr if so what company...
KW Suspension already has them out...but they're not cheap.
HHR kits range from $1325-1650 depending on the version you want.
You can see them HERE.
*Note: we have talked with several companies during the last year about putting our our own coil-over setups, but basically it runs 40-50k for us to get started. Coil-over design and build is not cheap.
Hope it helps,
Old Oct 3, 2006 | 07:52 AM
O6ChevyHHR's Avatar
so coilovers are adjustable, while springs like goldline arent, thats the deffrance between the two?
