pedders spring rattle
just installed pedders springs , now have a rattle on passenger side rear . anyone know what it could be
Just guessing.........maybe not sitting in the "channel" correctly. Maybe inverted the spring.
Welcome to the site badflt, up side down ?
:welcome8: to the forum badflt!
To echo those who preceded me, have you checked to see if its inverted, or did one of the spring insulators get left out? |
Originally Posted by 843de
(Post 640237)
To echo those who preceded me, have you checked to see if its inverted, or did one of the spring insulators get left out? If you no longer have them, you can either buy new ones or, as an old thread suggests, make your own. Thin foam or rubber will do it. |
I just ordered all new insulators from Rock Auto today for my upcoming spring install.
Just in case you need the part numbers badflt, the upper spring bumper/cushion is GM PN#25993737, the lower spring seat/cushion is GM PN#10362783.
You can get them at Rock Auto, or your dealer, etc. |
installed the springs the correct way and still had the noise , installed some rubber hose on the springs and all the noise went away and rides perfect
I posted earlier about the Pedders springs. I found mine to be coil binding pretty bad. New upper mounts, with top spring end aligned with upper spring seat tab, seems to cure it. Found neither side were aligned correctly, at spring install, the first time. "Moon"
| All times are GMT -5. The time now is 07:16 AM. |
