Proline Eibach and Turbo Tech Racing bar: is lower control bushing preloading needed?
Old Jan 20, 2010 | 04:35 PM
stranger's Avatar
Originally Posted by stranger
it gets firmer quicker
You're right it doesn't know where it is location wise. My comment was a play on words.
Old Jan 21, 2010 | 08:46 PM
IgottaWoody's Avatar
Depending on what tires your running, some of the sensed bounce may be sidewall flex,,, the tires may be picking up the load since the spring rates are stiffer...
Old Jan 21, 2010 | 10:12 PM
QuickRick's Avatar
I'll will post pix and measure.......
The drop over the weekend. It will have settled some by then, I expect about 2'' in back etc.
We will see.
QuickRick
Old Jan 24, 2010 | 09:35 PM
QuickRick's Avatar
New Eibachs
Guys,
I think I'll live with the car a while to sort it out. I have to say that it handles a lot better now and sits about an inch and a half lower. (not as low as Goldlines though)
Did those who had alignments done.....was there any adjustment needed or was it correct out of the box?
Check out my pix..not huge but not so ridiculus looking now.
https://www.chevyhhr.net/gallery/sho...=3&userid=9457
QuickRick
Old Jan 25, 2010 | 09:22 PM
I think this drop is just about right for these cars....gives em that stance and look of being serious.....the stock springs make it look top heavy...kinda like a van
Alot of people ran it lke it was and some had it aligned...HHR Boutique I believe has a set of numbers to use for the shop....otherwise the only thng to adjust is toe unless you install the camber kit....most of us have no wear problems as it is......
Old Jan 25, 2010 | 09:46 PM
QuickRick's Avatar
Woody,
I agree, I think of it as being on their "tip-toes" like a ballerina.
Chevrolet seems like one of the worst offenders of this look. I have lowered 3 Corvettes to get the correct stance. You won't see Audis or BMWs all hiked up in the air because they "get it" in the looks department.
QuickRick
Old Jan 25, 2010 | 10:16 PM
I always wondered why they have so much ground clearance which makes em feel wobbly, especially in winds....even the half ton trucks went up, think they are 4by s or something...
Old Jan 29, 2010 | 07:36 PM
QuickRick's Avatar
Lowered on the Eibachs
Guys,
I sware that the HHR appears lower than a week ago, I'm more pleased. The ride is a touch roughers but either I got used to it or else settling has helped out.
Perhaps I'll compare the readings in inches again this weekend and compare. It had gone down by roughly 1.5 inches all around last reading.
QuickRick
Old Feb 15, 2010 | 09:56 PM
QuickRick's Avatar
Eibachs
Guys and girls,
After driving through our recent east coast winter storm** either I'm used to the stiffer ride or the handling improvement is worth the small trade-off in cushiness.
I swear that car looks lower than when I did it a 4 weeks ago. (at the time of measurement it had 200 miles placed on it)
The rear wheel spacing way better than it did before the operation so it may have settled down a tad more recently.
I keep pushing it harder and harder around corners to see when it will break free, it handles much flatter than before. It used to be a bit "tippy".
I'm pleased.
QuickRick
**pix in the gallery under QuickRick
Old Feb 15, 2010 | 11:59 PM
Originally Posted by QuickRick
Guys,
QuickRick
I've never seen any springs settle by about 1.5 inches Something was not in right.. or ... ?
