Rear coil spring insulator
Old May 23, 2022 | 04:05 PM
RockAuto has the rear upper bump stop
https://www.rockauto.com/en/catalog/...ump+stop,19119
Old May 23, 2022 | 04:09 PM
Can be hard to see. The break on this spring would be hard to see unless you stuck your head up there.........
Old May 23, 2022 | 04:12 PM
Thank you sir, I was just gonna post that photo!
Old May 23, 2022 | 04:29 PM
mister hhr's Avatar
So it's broke where that rusted part of the spring is ?
Old May 23, 2022 | 04:38 PM
Yes. The pigtail end of the spring is broken off. It is no longer attached to the lower isolater.
Here are good springs that show the pigtail ends. Until you get under your car and find out what's loose or broken, there's not much else we can say. Tell us what you find.
Old May 23, 2022 | 04:42 PM
I usually stick my arm under and take a video with my cell phone, sometimes it’s clear
Old May 23, 2022 | 05:47 PM
mister hhr's Avatar
Thanks for the answers this is on my son's HHR I'll let everyone know what we find out it's been making this noise for a while now it doesn't seem to bother him .
Old May 23, 2022 | 09:00 PM
Before you lower the rear axle to remove the springs, do NOT forget to remove the brake line bracket bolt connected to rear axle / beam., or it can damaged stretching too far..
Old May 23, 2022 | 09:18 PM
mister hhr's Avatar
Thanks for the tip
Old May 24, 2022 | 07:25 AM
There’s a brake line bracket nut on both sides!
Look for this bracket
