Lower control arm bushings or entire arm?
Old 07-25-2018, 02:03 PM
hhr06NJ's Avatar
2nd shop told me must replace entire control arm
a friend of mine, works on Cobalts, say can replace bushings in 30 minutes
Advanced Auto sells bushings, front, rear, $18 each
what do you think?
hhr06NJ is offline
Old 07-25-2018, 02:13 PM
Here read these
https://www.chevyhhr.net/forums/how-...ol-arms-44378/
https://www.chevyhhr.net/forums/brak...bushing-60188/
https://www.chevyhhr.net/forums/brak...rol-arm-60599/
Oldblue is offline
Old 07-25-2018, 02:24 PM
Technical Moderator
Labor!
It is very easy to beat the flat rate for a complete arm. Not so much replacing bits.
Most people are convinced that you must use a hydraulic press (I used to be) and not many shops have them anymore. Not many shops have the Kent-Moore equivalent tool either.
Mechanics think in terms of beating the flat rate!
for both complete control arms 1.8 hours
for both bushings 2.2 hours
I replaced both sides on mine in my garage on the floor in less than 45 minutes. And I actually respected torque, a shop mechanic will save 10 minutes with the impact gun.
So would you rather get paid for 1.8 hours and do 30 minutes work or get paid for 2.2 hours and do 70 minutes work? If you spent the money on the right tool it would only take 45 minutes, but you still have to R&R.
I had the buffoons at Firestone tell me the same thing, "and unfortunately, the DEALER doesn't have one in stock".
donbrew is offline
Old 07-25-2018, 03:47 PM
Cat Man HHR's Avatar
what do you think?
If he can then do it.
The guy must be like:
Cat Man HHR is offline
Old 08-08-2018, 06:41 PM
AZGARY's Avatar
I have a 2009 HHR with 81,000 miles and had the front end clunk. I bought the pair of lower control arms complete from Detroit Axle for $58.25 including shipping. I found a shop that installed them both and did an alignment for $150.00. Rides and drives like new.
AZGARY is offline
Old 08-08-2018, 07:11 PM
If you mean these, they for a Cobalt, not strong enough for the HHR
all HHR’s came with the stronger aluminum LCA’s
you get what you pay for. They’re fine for light unloaded driving
https://www.detroitaxle.com/shop/sus...nt-assembly-9/
Oldblue is offline
Old 08-09-2018, 07:58 AM
Here's a question I've asked myself. Why are the Cobalt and HHR built on the same platform but only the Cobalt SS have the Aluminium lower control arms? If the Aluminium are stronger than the steel ones. Do the steel ones rot out?
I did find this and this place only sells/offers Aluminium lower arms for FE1/3 suspensions:
https://www.1aauto.com/control-arm-with-ball-joint-pair/i/1asfk00568?f=584426&gclid=Cj0KCQjwzK_bBRDDARIsAFQF 7zOohP7B5tKTDcVatkxjSaVyeDxYvZx0n3YvxJTZvKo7FGKjyl 7HWBAaAsdZEALw_wcB
Edit: I do see what Blue posted for a part that only fits/used for FE1 suspensions. FE1 has the softest springs that I know of. But what constitutes "fine for unloaded driving"? Don't people on this forum have an LS and use it for more then going to the store?
Old 08-09-2018, 08:09 AM
You’d have to ask pre bankruptcy GM bean counters, as to why aluminum for the HHR and steel for the Cobalts?
and how come the Cobalts had 4 lug axle hubs?
They are a lighter weight car.
Oldblue is offline
Old 08-09-2018, 08:32 AM
Technical Moderator
In after-market terms there is no difference I can find between FE1/FE3. I don't know what could possibly be different in LCAs, the rear bushings are identical.
donbrew is offline
R CA HHR
37
08-06-2019 08:15 AM
hhrfreek
11-24-2011 02:19 PM
bigw10921
07-17-2010 10:35 AM
Quick Reply: Lower control arm bushings or entire arm?
