Rear spring isolators
Old Apr 25, 2011 | 08:30 AM
frentzjr's Avatar
I put the gen1 Goldline lower springs on my car last weekend. When I removed the stock springs, the spring isolators were almost completely destroyed. I went to every parts store in the area, and no one has a replacement piece for this. When I went to the GM parts department, they said that I would have to order the entire upper spring housing which is over $100. Does anyone know of a better solution than replacing the entire upper mount?
Old Apr 25, 2011 | 10:40 AM
HHR_style's Avatar
go to a junk yard or check eBay
Old Apr 25, 2011 | 10:42 AM
frentzjr's Avatar
That was my first thought, I didn't know if someone knew of a better solution.
Old Apr 25, 2011 | 11:56 AM
speedwagen's Avatar
could you rebuild yours with a donut cut from a sheet of plastic, or hard rubber
Old Apr 25, 2011 | 12:42 PM
B1GP1MP1N's Avatar
I replaced my with a rubber material I found at Homedepot. Laid the old one down to judge for size. The felt material they use is worthless.
Old Apr 26, 2011 | 11:15 PM
PhoS's Avatar
90 shore urethane would work awesome , just gotta make a mold. Probably would be quieter too.
Old Apr 26, 2011 | 11:59 PM
Felt material ??
Old Apr 27, 2011 | 02:56 PM
HHorange's Avatar
Do what we used to do in the old days.... Buy a piece of heater hose and slice it lengthwise, and slip it over the top coil on the spring. You can secure it with a couple of plastic wire ties to hold it in place till the cars weight is on it.
Old Apr 27, 2011 | 03:43 PM
LewiSS's Avatar
HHorange, right on. Worked well for us on a bunch of cars, too. I have heard the hose might roll over and come out, but never had that problem. I went with shorter springs on a (then new) '75 Corolla SR5 and had to tie wrap the srping to the perch - if the suspension topped out over a bump, the spring was short enough to jump out of it's place. So, you might want to use the hose and tie wrap the spring in place just in case.
Old Apr 28, 2011 | 08:05 AM
B1GP1MP1N's Avatar
Originally Posted by sleeper
Felt material ??
I guess foam is a better word. Whatever it was, it didn't hold up very well.
