Rear springs
Old Jul 3, 2011 | 01:24 PM
moonsign's Avatar
Due to the FWD platform, a slight rake[slightly lower in front] is the better setup, both for traction and handling. RWD is just the reverse.
You need to transfer the weight to the driving wheels, which in this case is the front wheels. If you don't care about better traction or handling, then it does'nt matter which end is lower. "Moon"
Old Jul 3, 2011 | 04:55 PM
hhrfreek's Avatar
That sounds right, but it seems that a stiffer rear suspension in general will help with better traction and handling. I already noticed just the opposite of what you explained...The stiffer setup with the tc springs/shocks has allowed better traction in cornering and digs by limiting the weight shift or body roll of the car...and this was accomplished by lowering the rear only. I really think that even if I had the sc springs and sat lower in the rear I would have noticed improvements over the FE1 suspension because it is so soft. So I am sure greater improvements would be made by using the FE5 Springs/shocks to rake the front to spec, but the stiffness on its own helps a lot.
Old Jul 4, 2011 | 01:54 AM
Mine hugs like on rails & still has good ride quality.. I have the FE3 & TC set-up & etc..
My only limit now as I see it, is needing stickier tires.
Old Aug 11, 2011 | 09:24 PM
Zombie's Avatar
I own a 2011 panel and I want to level it out. What year tc springs can i use to do it.
Old Aug 11, 2011 | 11:17 PM
Zombie-
I've installed '08-'09 Cobalt SS/TC rear springs on mine almost 2 yrs ago. Just right, imo.. GM Part# 25821162
Softer & lower 'balt springs are '05-6-'07 SS/SC GM part# 10390024
Old Aug 13, 2011 | 06:45 AM
  #26
Zombie's Avatar
Thanks sleeper. Guess im going parts shopping.
Old Aug 13, 2011 | 10:38 PM
  #27
I got mine from GM parts direct. $82. to my door...But that was almost 2 yrs ago..
Lots of sources..
Old Aug 14, 2011 | 09:08 AM
  #28
Zombie's Avatar
Yeah i just checked them out this morning and it will cost me 71.00 door to door. I am going to my local dealer on monday morn just to compare prices. What rear sway bar are you using with these springs?
Old Aug 14, 2011 | 09:22 AM
  #29
I have a used TTR 1" I will sell for 100 + shipping I want to get the XXX
Old Aug 14, 2011 | 11:20 PM
  #30
Zombie- decent price, be curious to what price your dealer quotes for a price..
I've been using the ttr bar, but plan to upgrade to a Powell Street Bar.
retrolled
Sep 12, 2013 11:40 PM
donbrew
Nov 24, 2011 08:07 PM
