replacing lower control arms/bushings
Old Oct 29, 2017 | 02:07 PM
Ok, thanks for the explanation.
Old Oct 29, 2017 | 02:09 PM
Pretty sure the solid ones do have a top and bottom, I think the outside band might be tapered.
Oldblue has done it before, he's the authority.
Old Oct 29, 2017 | 05:25 PM
The bushings have a rounded edge this will be the bottom, press it into the lca with the balljoint pin pointing up.
Old Oct 30, 2017 | 01:15 AM
serch826's Avatar
Okay, Thank you for your help.
Old Oct 30, 2017 | 12:55 PM
Welcome!
Old Aug 5, 2019 | 05:21 PM
  #26
Doncoldwater's Avatar
Paid to much
I have a 2011 HHR, I paid a local mechanic $973.87 for both upper and lower control bars today. Is that a little ridiculous ?
Old Aug 5, 2019 | 05:35 PM
  #27
Yes it doesn’t have upper control bars!
Old Aug 5, 2019 | 05:51 PM
  #28
The GM flat rate book says
$202 each parts (that is a lot more than NAPA charges)
1.8 hours labor for both.
1.0 hour labor alignment
I don't know what an upper control arm is, maybe they meant strut
That would be about
$136 each for parts
There should be a discount on the labor since it is mostly duplication. for both struts there would be an additional 6 nuts of work.
Old Aug 5, 2019 | 06:12 PM
  #29
Ok
Is it left and right ? Both were changed.
Old Aug 5, 2019 | 06:18 PM
  #30
The invoice says right right and left premium grade control arms with ball joints.
