shocks
Old Dec 18, 2009 | 11:21 AM
'Lil Red Wagon's Avatar
Cool shocks
I am going to put '08 Coablt SS rear springs on my '07 Panel Wagon, should I also put Cobalt SS shocks on too? I don't know if the HHR shocks will bottom out with the Cobalt sptings.
Old Dec 18, 2009 | 12:00 PM
the_shmoo's Avatar
I have Cobalt SS/SC rear springs with the stock shocks and have not bottomed out yet. Lowered the rear 1". Also did not trim the bump stop. Hope this helps.
Old Dec 18, 2009 | 12:39 PM
txbass06's Avatar
I've been told that shock replacement isn't required for a drop 1'' or less
Old Dec 18, 2009 | 11:30 PM
Thumbs up
My stock FE3 sport tuned HHR rear shocks are not bottoming out at all, & I do at times haul some slightly heavy stuff, besides just hauling azz.......
And didn't trim bump-stops either. 1" drop in rear leveled mine (as planned), & made it handle much better. I used the 'balt SS/TC rear springs.
I think you should be very happy with the spring change..
I added a rear sway bar (yesterday) but due to steady raining, haven't been out for any spirited testing, yet..
Old Dec 20, 2009 | 04:44 PM
Thumbs up Shocks
Thanks for the info everyone!!! Now, what is the difference between the SS/SC and the SS/TC. I'm sure it's the ride, I don't want to be tooo still my HHR is just a pleasure ride (just luggage on trips and some light stuff around town). I am also going to do the sway bar.
Old Dec 20, 2009 | 09:24 PM
txbass06's Avatar
I believe the only difference is the TC springs are stiffer but offer the same drop
Old Dec 20, 2009 | 10:01 PM
xzombiex66's Avatar
Only time my shocks bottomed out was when i had 550lbs of landscaping stones in the back of it.
Old Dec 20, 2009 | 10:38 PM
Thumbs up Shocks
Thanks for the info, SC or TC shock, which give the smoother ride with a sway bar? Is there a sway bar set up that matches the stock front sway bar for ride? You guys are the best, you really know your stuff,glad I joined this site!!
Old Dec 20, 2009 | 10:45 PM
Thumbs up Shocks
THAT was FAST, thanks !!!!! I'll probably go the SC for the smoother ride. Any info on sway bars that work well with the stock suspension?
Old Dec 20, 2009 | 11:04 PM
prod's Avatar
I have the progressive tech sway bar. Its not as thick as the TTR so it is a little easier on the ride quality. Still controls body lean in the corners quite well.
