SPRING question.
HEllo
Its me again. Guys i would like to shere a site with You https://www.gmpartsonline.net/auto-p...-l4-gas-engine You can fin oryginal parts by catalogue. But i need some pro info i need springs https://www.gmpartsonline.net/oem-pa...bC1sNC1nYXM%3D None of cars listed as "parts used also for" is available on Polish market, so i need to find the model of Opel that uses the same part in that case a spring. Do You think that Vectra C or Zafira B are using the same springs ? if yes from which year ? |
We don't have those cars here so we don't know.
However the HHR is heavier then those cars, so the springs might if but not carry the weight Fitment chart for that part number https://www.gmpartsdirect.com/oem-pa...&recommended=1 Same for this https://www.gmpartsonline.net/oem-pa...w0LWdhcw%3D%3D These Front springs the coil winding doesn't look right! http://m.ebay.ie/itm/VAUXHALL-VECTRA...%257Ciid%253A3 |
gm part number is not available on EU market under the number
22735635 is it possible that GM EUROPE uses differen part numbers than Your GM ? |
Yes it's possible I was looking at images of the front coils they look just enough different to not fit
1 Attachment(s)
Her is a list of cars built on the same platform, chassis parts may be interchangeable; no guarantee though.
Attachment 45405 |
Originally Posted by donbrew
(Post 828639)
Attachment 45405 |
Originally Posted by Oldblue
(Post 828637)
The top is smaller winding or spin than the bottom, like these
https://www.suspension.com/prodimage...58-large-1.jpg |
1 Attachment(s)
These are HHR springs. 1 front, 1 rear. Only the rears will have the pigtail curve on the ends.
(these are SS springs but have the same physical look as the regular HHR springs ) Attachment 45406 |
The left spring in FMG's picture is the front spring , it's hard to see but the top wind is slightly tighter than the rest of the spring.
I the picture I posted they are HHR front springs the tighter winding is show on the right of the picture |
