Chevy HHR Network
-   Brakes | Suspension | Shocks | Struts (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/)
-   -   SS HHR parts inter change with other HHR models (https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/ss-hhr-parts-inter-change-other-hhr-models-61646/)
MichaelJ2 Apr 19, 2019 12:33 PM
Here's my question. I wish to put on SS model front hub bearing assembly on my 2006 LT Model HHR.
Will there be a problem in doing so? Has anyone else done so?
donbrew Apr 19, 2019 01:59 PM
The answer is no, does not fit. They are different part numbers, I don't know what the difference is. I know the steering knuckles are different.
Question is why?
RJ_RS_SS_350 Apr 19, 2019 03:52 PM
The SS axle shafts are larger, and are splined differently.
MichaelJ2 Apr 19, 2019 04:05 PM
I'm just interested in the front hub bearing?
donbrew Apr 19, 2019 04:17 PM
The axle fits into the bearing; thus they need to match.
Ohiocruiser Apr 20, 2019 05:21 PM
If you want to install ss hub bearings on non ss model, you will have to replace all suspension to ss parts.
Lethal Tendencies Apr 23, 2019 11:36 AM
I thought all front wheel bearings were the same on all models
Lonwane Apr 23, 2019 02:32 PM
LS and LT yep.
SS, different beast.
donbrew Apr 23, 2019 02:52 PM
See post #3
Blue_SS Apr 23, 2019 05:50 PM
The info in here is correct.
