Suspension Popping/Clunking
I'm in need of some help my suspension problems with my 2008 HHR SS it has been to 3 Different shops and nobody can give an honest Answer about what is. When I'm going on uneven roads my Suspension pops/clunking Noise and when im going about 20mph and Steer left to right Repeatedly it Pops on both sides. I recently just replace these struts and the Hub Assembly if Anybody has a honest answer about what it is Please feel free to message.
Could be lower control arm bushings, sway bar end links swaybar bushings, ball joints
LCA bushings are a possibility.
If somebody put 12" sway bar end links on it they can bang on the LCA's, along with that the plastic stops on the bar can move allowing it to go back and forth excessively. Could be the spring insulators on the struts, could be you were sold the incorrect struts (especially if they were complete assemblies). See the link in my sig for diagnosing suspension noises. |
Ok i will have to look more in to that Is there a way to check To see if Those things are bad are will I have to guess. The last shop I had it in said all my bushings and everything were good and that my struts were bad even though I just replace them Is there a certain type of strut to use
The SS has a different strut from the LS/LT, if you got them saying "fits all" they are wrong. If you got complete struts, including the springs you probably got LT/LS struts, since nobody has been able to locate those for the SS.
The Lower Control Arm bushings are difficult to see, but can be checked with a crow bar. You can look at the Lower Control Arms, if you see a mark on them near the sway bar end links, that is the bang. You can look at the sway bar, just inside the bushings there is supposed to be a plastic collar/stop. You can measure the sway bar end links, the correct ones will be approx. 10 inches center to center. Most parts books list the WRONG 12 inch part. Have you checked the sway bar bushings? They can "look" good, but have play. Check with crow bar. |
Yea my struts didnt come Complete it was just the strut Its self. The struts i Ordered and got on there are KYB struts And I have replace the stabilizer bar that Connects to the sway bar and the strut and it is 10 inches i had new Sway bar bushings but the ones that were on there didn't seem to look bad so I took them back
Check the lca rear bushings
Oldblue, do you think it could be any of the steering parts you've had to deal with?
And since it is an SS; somebody may have replaced the LCA already with the WRONG ones. The parts books ALL list the one with the too small ball joints. get a micrometer and measure the diameter of the ball joint studs; they should measure 20.5 MM. Or look at them, if they are black they are wrong, they should be cast aluminum.
ok thank everybody for the suggestion for the struts what type of struts do the SS take because I mite have put the wrong ones on when I did mine I know their is different strength of FE
| All times are GMT -5. The time now is 05:14 AM. |
