Suspension Popping/Clunking
Old Oct 15, 2017 | 10:31 AM
Cody26's Avatar
I was think about just replacing the strut with the FE5 since i have to take the other ones off anyways. But it could only be 3 things i sprayed WD40 on the A frame bushing, sway bar bushing and the bottom of the strut wheir the coil sits and underneath the mount and the clunking stop for a while but then came back
Old Oct 15, 2017 | 11:33 AM
Well how’s about spraying one place at a time now to narrow down the parts
According to these reviews the KYB’s are preferred for the FE5 SS
https://zzperformance.com/ecotec/kyb...-g-struts.html
Old Oct 15, 2017 | 02:21 PM
Cody26's Avatar
Maybe the mounts are just bad but i didnt get them from zzp i Ordered mine off of summit i think mine are FE3 but i will Respray the swaybar bushing and the a frame bushings and will update later
Old Nov 1, 2017 | 03:19 PM
bad03xtreme's Avatar
I am having a similar issue in my '08. I just ordered the CABs from OTTP and I hope to do those along with the sway bar end links and bushings. Hopefully that will tighten up everything in the front end.
http://www.ottperformance.com/store/...&idcategory=41
Old Nov 1, 2017 | 03:24 PM
Iginore most parts that claim to "fit all" if you have an SS.
Old Nov 1, 2017 | 03:56 PM
  #26
You could have better weather protection and same performance out of these!
Front Lower Control Arm Bushing | Chevrolet Cavalier
The front pivot bushing rarely fails.
Old Nov 7, 2017 | 06:17 PM
  #27
Blue_SS's Avatar
I would bet on the rear LCA bushing.
But, OP, KYB does not belong on an SS. They may fit, but "wallowing" is not in the SS' vocabulary. Reconsider.
Scott Sloan
Feb 17, 2017 05:42 PM
JMichael
Oct 23, 2012 05:19 PM
rewcolee1
Mar 30, 2007 05:56 PM
pontfirebird73
Jul 17, 2006 10:49 AM
slamed87lincoln
May 22, 2006 06:41 AM
