Suspension Question
Hello all, I just joined the site and have learned much by reading/searching through the forums. I recently bought a 2006 LT and am currently trying to decide on a new suspension set up as my front factory struts are leaking.
I am thinking of going with the H&R sport springs (progressive), KYB struts and shocks (Excel G/GR-2), and the progress technology rear sway bar (22mm). I'm only looking for a mild lowering with overall better performance and durability. I don't mind a bit of ride harshness, but since this is my daily driver I don't need anything extreme. Also, I'm currently running the stock 17" wheels with Kuhmo Ecsta LX Platinum tires. From searching I found one person who has a similar setup and they seem very happy with it. My main concern is durability. I understand that the KYB's are a replacement for the FE3 suspension components which are what the LT currently has. Will the 1" front/1.2" rear drop that the H&R springs provide be detrimental to the lifespan of the KYB's or can they handle that with no problem? Any insight that you all could provide would be greatly appreciated! :bow: |
Welcome! That setup sounds like it will deliver about what you are looking for. I have had good luck with GR-2s on other vehicles, but usually at or near stock height. I used KYB AGX (adjustable gas struts) on the one that was lowered significantly, and they went over 100K and about 4.5 years before I sold the car. So, I am leaning toward saying yes on this, though I have no model-specific knowledge to base it on.
The spring rate is what would make the difference. On my lowered car, the rates were nearly twice as stiff - as a reference point. The rear sway bar is all good. You won't notice anything negative. |
| All times are GMT -5. The time now is 06:53 AM. |
