Suspension Squeak In Cold Weather Fix?
Old Jan 29, 2010 | 02:54 PM
bunkie's Avatar
Originally Posted by ouhockeyplayer
I was just thinking that if this is going to happen every year. Any suggestions on aftermarket bushings to look into?
Sense changing bushings is the same procedure as changing sway bars I'd opt for a new Eibach bar and fix two(posible) issues at the same time.
Old Jan 31, 2010 | 10:33 AM
jerSSey HHR's Avatar
I only notice it when it's REALLY cold.
Old Jan 31, 2010 | 10:49 AM
THE BATMAN's Avatar
Mine has also been in 4-5 times for this ,among other issues, Right now I'm at 38000 miles . It was taken in at 35,500 miles and has an open case with GM, And will be covered untill they fix it, Per GM.
Originally Posted by ecl
Had mine in 4 or 5 times to get this fixed and its still not fixed the local dealer gave up and wont touch it now that its out of warranty unless of course I want to pay to have them fix it. Seeing as they cant seem to fix yet Ill live with it for now, since the cold weather is almost done. I would also like to know what kind of after market bushings to look at, maybe I'll just get it done my self this summer and then see what happens next winter.
was just looking around and on the other HHR forum theres a guy running these http://www.energysuspensionparts.com...sp?prod=9.5161 think I will be getting a set of these in just a while. Here is the link to that thread as well incase any one was wondering.
Old Jan 31, 2010 | 05:51 PM
STEVEN M's Avatar
I've been running the greasable sway bar bushings from energysuspension,have been in 5 degree weather and noise has not returned.however, these bushings lower the sway bar and make it really close to the k-frame.I put one quarter inch plate under mine,2 inches wide by 4 and one half inches long.this also gives the bushings a good flat spot to sit,as there is a dip in frame that factory bushings sat in.
Old Jan 31, 2010 | 06:56 PM
ecl's Avatar
ecl
Thats what they told me also however they cant find the issue no matter what I/they suggest and no other dealer will look at since its not under warranty any more. I mean they replaced the the steering column thinking that would cure it even though its a suspension noise and you can tell. Im just sick of fighting with them and figure if for 20 bucks I can fix it myself might as well, and then less of a headache all around.
Old Jan 31, 2010 | 07:19 PM
THE BATMAN's Avatar
It seems a lot of us are having this issue, Someones got to know a proper fix
Old Feb 1, 2010 | 05:31 AM
gmdealerguy's Avatar
The stock bushings are crap. When I had my 07 HHR,they were replaced 4 times. Now my 09 SS is squeaking like a 40 year old car. I have 10,080 miles on mine and it sounds awful in anything colder than 30 degrees.
Old Feb 1, 2010 | 05:41 AM
Jeff®'s Avatar
My fix: Summer.
Old Feb 2, 2010 | 10:21 AM
ouhockeyplayer's Avatar
Well I just followed up with the dealer and they informed me that the bushings are now on back order and don't know when they will get them. Guess I'm living with the squeaks and clanks of the front end for awhile now.
Old Feb 2, 2010 | 12:44 PM
MWG2's Avatar
Crisco grease liberally applied to the bushings worked for me....just kidding.
