Swaybar end links
Old 01-20-2018, 10:38 PM
mryuk's Avatar
Swaybar end links
I have a 2006 LT 2.4. 5dr none ABS. Auto I'm having to replace swaybar end links for the 2nd time in a year first ones where moog. The ones I have bought now are A.c. Delco. I replaced the bushings the two struts complete the ones I got I was told took the 9.3/4 length not the longer ones is this true ? Is there a code in the glove box I can go too to get the chassis code ? Also I was told there was a factory recall for the steering? The new links are Delco # 19237776 those are the shorter ones ! But I also got the longer ones just in case Delco # 19148626 can anyone help me with this ?
mryuk is offline
Old 01-20-2018, 10:47 PM
Hi mryuk, to the forums!
Sounds like you have the right end links. No recall, but an extended warranty.
EDIT: You edited your post while I was replying. I'll research those numbers and be right back
RJ_RS_SS_350 is offline
Old 01-20-2018, 10:53 PM
mryuk's Avatar
so it's the shorter ones I'm hoping this is the last time to replace for a bit more then a year 😎it do,s have 215000 km on it but that should be nothing for chev 😊
mryuk is offline
Old 01-20-2018, 10:59 PM
mryuk's Avatar
Thanks to for allowing me to be part of the group !😎4
mryuk is offline
Old 01-20-2018, 11:09 PM
OK, the 19237776 is correct for 2006 HHR. Discontinued, but correct, so if you have them, they'll work. You could also use the newer parts - GM P/N 20784688; or 20784687(for FE5, but should still work fine).
You have the 2.4, so it's a 2LT, so it's got FE3 suspension. Should be on the glovebox sticker.
Old 01-20-2018, 11:41 PM
mryuk's Avatar
wow thanks you guys are a big help I'll keep you posted ps I love Gm this my 36 vehicle most of them GM's everything from early Vegas to monzas chev pickups and more . I have to see one thing HHR very unique and versatile I've had a lot of positive compliments on them on the vehicle.
mryuk is offline
Old 01-21-2018, 08:31 AM
Look for FE1 or FE3 on that glove box sticker.
Just to clarify, what failed in the Moog sway bar end links?
I’ve had mine for several years without any problems.
According to this site Moog offers a lifetime warranty.
http://www.moog-suspension-parts.com/moog-k750012
Oldblue is offline
Old 01-21-2018, 08:51 PM
fastsuv's Avatar
Just as a slight clarification, in 2006 the 2.4 was optional on the 1LT, so it doesn't have to be a 2LT. I have 3 2006 1LTs with 2.4s.
Steve
fastsuv is online now
Old 01-21-2018, 09:17 PM
Steve
Dang, little brain fart. Thanks for the tune up Steve!
2.4 = LT1 = FE1 OR LT2 = FE3(like Oldblue was hinting at)
Old 01-22-2018, 07:06 AM
2LT the Suspension was FE1 Standard or FE3 optional.
No hints , just the facts.
Oldblue is offline
Quick Reply: Swaybar end links
