Tall Rally style Coilovers
I'm looking for solid coilovers that can accommodate a slightly taller than stock ride height and work well in rough conditions. I'm sick of bending rims bottoming out on potholes.
This guy has Malibu struts in front and PT Cruiser springs in the back, I think. Didn’t add a lot, maybe less than 2 inches? Will try to remember which generation of Malibu. 2009 sticks in my mind but not sure. Your car came with FE1 “soft ride” dampeners. Just switching to the SS dampeners might help a bit.
https://cimg8.ibsrv.net/gimg/www.che...d1336a9dd.jpeg |
(Post 923611)
Rims bend , no matter your ride height, you need stiffer side walls in your tires! And taller springs
https://www.spaccer.com/en_CA/makes-...vrolet/hhr-434 |
Originally Posted by Oldblue
(Post 923621)
(Post 923621)
I’ve bent the rims on my daully, train tracks are brutal, I upgraded to more ply tires!
(Post 923624)
Off road , yes they should last , but on road there’s so many more obstacles, potholes, train tracks, frost joints on bridges, curbs
Off road tires are also designed to handle and protect the rims from rocks and logs and rough landings |
| All times are GMT -5. The time now is 05:13 AM. |
