Tire Pressures
Old Jan 12, 2009 | 05:06 PM
mo650chopper's Avatar
Tire Pressures
Not sure if this is the best place but I've noticed my stock Firestone's on my 2008 HHR say max load at 44 PSI but the tag on the drivers door says 35 PSI. Just curious on what everybody's running in theirs? I know higher pressure would increase tire life & mileage but sacrifice ride and traction.
Old Jan 12, 2009 | 06:32 PM
catdaddy137's Avatar
at least
35 COLD = 37-8 hot/warm , i plan on going up 2 psi. no way i would run 44 cold, maybe 40 cold. at less than 35 it does ride a little better , but it will decrease mpg. i believe over 37 cold decreases traction on ice/snow.
Old Jan 12, 2009 | 10:55 PM
masterchief1112's Avatar
my door says 30 psi. is this wrong
Old Jan 12, 2009 | 11:45 PM
1Panel2NV's Avatar
No, you probably just have 16'' wheels.
Old Jan 13, 2009 | 02:36 AM
IgottaWoody's Avatar
Too much air bows the center of the tire out causing the centers to wear much faster..also lifts the side edges reducing tire patch contact. With the 18's Ive noticed quite a bit a difference when pressures get below 30, but then theres not a lot of volume there so it will let you knwe a lot sooner then a reg sidewal tire.
Old Jan 13, 2009 | 07:15 AM
hhrcrafty's Avatar
The manufacturer determines the recommended tire pressure for the vehicle based on weight and handling characteristics. Remember when all those Firestones were failing on the Ford Explorer? Part of the problem was the recommended tire pressures for the vehicle, which Ford had set lower to reduce the risk of rollover.
My car says 30 PSI. It may be different from year to year or between handling/suspension packages. I usually run 35 for a little better mileage.
Old Jan 13, 2009 | 07:27 AM
solman98's Avatar
Not exactly true. They lowered the pressure to make it ride better. The results...... Seperated tires and rolling over due to low tire pressure.
The Ford Explorer sport-utility vehicle rolls over more often than other SUV's do in tire-tread accidents, and it has vibration and suspension problems that Ford can't always explain and sometimes can't fix. Those flaws raise the suspicion that the Explorer itself is contributing to the sometimes fatal accidents that forced the Bridgestone/Firestone recall. An internal memo from Ford of Venezuela says that the Explorer "turned over unexpectedly" when Firestone tires lost their treads, but that other SUV's didn't in similar circumstances. About 31% of Explorer complaints cited mysterious vibrations. Many could not be cured, even after dealers changed tires, shock absorbers and drive-shafts. Less frequent is an odd tire-wear pattern called "cupping." It shows up in less than 2% of Explorer complaints, but never shows up in most other Ford truck models.
http://www.firestone-tire-recall.com.../overview.html
The Ford Explorer was first offered for sale in March 1990. Ford internal documents show the company engineers recommended changes to the vehicle design after it rolled over in company tests prior to introduction, but other than a few minor changes, the suspension and track width were not changed. Instead, Ford, which sets the specifications for the manufacture of its tires, decided to remove air from the tires, lowering the recommended psi to 26. The Firestone-recommended psi molded into the tire for maximum load is 35psi.
The failures all involved tread separation—the tread peeling off followed often by tire disintegration. If that happened, and the vehicle was running at speed, there was a high likelihood of the vehicle leaving the road and rolling over. Many rollovers cause serious injury and even death; it has been estimated that over 250 deaths and more than 3,000 serious injuries resulted from these failures.
Ford and Firestone have both blamed the other for the failures, which has led to the severing of relations between the two companies. Firestone has claimed that they have found no faults in design nor manufacture, and that failures have been caused by Ford's recommended tire pressure being too low and the Explorer's design. Ford, meanwhile, point out that Goodyear tires to the same specification have a spotless safety record when installed on the Explorer, although an extra liner was included into the Goodyear design after recommendations to that effect were made to Ford. Firestone included an extra liner in its product and this was then also used to replace tires on Ford Explorers.
http://en.wikipedia.org/wiki/Firesto...re_controversy
Old Jan 13, 2009 | 07:46 AM
i installed tires
for a few years. i could be wrong , but i beiieve it is best to go by what is on the tire mostly , but the door tag may tell you what tire is recomended. most installers put 32 in most tires , cold, when you ride it will increase -from friction- to about 34-5. all tires should have on the sidewall what it's maximum load and pressure is. too much or too little air can cause tire failure , poor handling/performance , uneven/premature wear.
optwovettes
Jul 31, 2012 05:58 AM
bthomas515
Tires & Wheels
13
Jun 11, 2011 08:03 PM
birdflames
Sep 29, 2009 11:48 PM
Seeburg220
Tires & Wheels
27
Sep 21, 2007 12:44 AM
cj krause
Tires & Wheels
Aug 3, 2006 06:46 PM
