Warped rotors?
i have steering wheel shudder when braking. dealer has turned rotors twice. no help .i want to upgrade rotors & pads. i prefer brand name. ceramic pads & drilled /slotted? the car has 15000 mls. ebc reds or hawk. suggestions appreciated. also cc stopped working after last dealer visit. coincidence?
When you do get them replaced. be sure your rear brakes are adjusted properly. My fronts went out in a very short while after the mechanic didn't feel it was necessary to adjust the rears on replacement. It makes the fronts do all of the work and they warp. There are many, many posts on warped rotors on our site. Check them out.
i did read some of posts. based on what i read i want to upgrade instead of replace with gm units. dealer will install & give me credit for gm rotors.
What is "cc" ?? See you have an SS so adjusting the brakes is not an issue. Do you have Brembos? Choices can be limited when replacing Brembo rotors and pads.
no brembos. Cruise Control.
Originally Posted by AJochum
(Post 605225)
It is definately worth checking. |
i will make sure they adjust rears. still need suggestions on best rotor /pad combo.
SS has 4 wheel disc brakes
Originally Posted by FURIOUS10
(Post 605242)
gotcha. was confused for a bit there.
| All times are GMT -5. The time now is 07:02 AM. |
