Wheel bearing replacement
Old Feb 27, 2012 | 08:45 AM
  #61
solman98's Avatar
Originally Posted by Kookie
I don't see that in the manual (Unless you have an updated service bulletin or something). I have the 2006 Chevrolet HHR Service Manual, A SUV (GMT/06-A-1). In volume 1 section 3-26 is the wheel bearing/hub replacement - front instructions. It doesn't mention replacing the axle shaft nut. Only the spec to tighten to 81 ft lbs. I do believe that is a lock nut.
Originally Posted by donbrew
My manual "2006 HHR Service Manual" specifies 155 lb ft torque, maybe you have the update. The nut comes with an axle, and every mention I have found says to use a new one, not to say I always have. They are of a type of 1 use nut, not exactly a squash nut more like an exhaust flange nut, like very tight tolerance (don't remember the name).
Big differance between 81 & 155 lb ft, which is correct? I've got a set if AC Delco's that I purchased for when I do replace them, would be nice to know the correct lb ft to use. I was told in the past it was 81 lb ft, hub bolts to 85 lb ft.
Old Feb 27, 2012 | 10:23 AM
  #62
barfan1's Avatar
155 Ft. Lbs. is the correct spec, and don't re-use the nut, get a new one
Old Feb 27, 2012 | 11:49 AM
  #63
solman98's Avatar
I've already got the nuts and the 30mm socket. Everything I've seen in the past, including chiltons stated 81 lb ft for the axle nut. Now this 155 lb ft is mentioned. Seems like if it is only 81, then 155 would damage it. But on the other hand, if it's supposed to 155, then 81 would not be tight enough.
So where is this 155 coming from? What referance?
Here is Chiltons.
1.Before servicing the vehicle, refer to the Precautions Section.
2.Raise and support the vehicle.
3.Remove the wheel.
4.Remove the rotor.
5.Remove the axle shaft nut.
6.Remove the wheel speed sensor connector.
7.Remove the wheel bearing bearing/hub assembly bolt.
8.Remove the wheel bearing/hub assembly bearing.
9.Remove the wheel bearing/hub assembly spacer.
10.Installation is the reverse of removal. Torque the axle shaft nut to 81 ft. lbs. (110 Nm); the hub bolts to 85 ft. lbs. (115 Nm).
Old Mar 1, 2012 | 11:02 AM
  #64
barfan1's Avatar
The only place in Mitchell 5 where I see 81 ft.lbs. is in the hub assembly section for 2006 HHR. In the axle repair sections it is 155, for all other year HHR's it is 155 and for the Cobalt it is 155, all years. I went through this process when I replaced mine last year and I can tell you that the factory nut is on with 155, no where near 81. And if GM changed the spec there would have been a TSB and I found none.
Old Mar 1, 2012 | 11:10 AM
  #65
I just checked the GM shop manual for a 2006 - it too refers to 155 lb ft (or 210 N.m). Also noted that it refers to using a drift or punch inserted thru the back side of the caliper into the rotor, to keep it from turning when removing the axle nut. And would work when installing the nut as well I assume.
Old Mar 1, 2012 | 11:41 AM
  #66
solman98's Avatar
Well thanks for the info, amazing how big a differance different referances tell you.
Old Mar 1, 2012 | 12:19 PM
  #67
css9450's Avatar
That's how we do it in the junkyard - jam a large screwdriver through the top of the caliper and as far into the cooling fins on the rotor as it'll go. The only danger is if it snaps! You're likely to go for a tumble.
Old Mar 1, 2012 | 02:43 PM
  #68
the other way, is to tighten it up till it strips..... then back it off 1/4 turn!! *G*
Old Mar 1, 2012 | 06:50 PM
  #69
I DO vaguely remember that my first new set of front hubs had an insert that said that there was a "new" torque setting, don't remember what it was. I don't really see why it would make a difference, the thru axle goes metal/metal/metal vs. metal/bearing/metal, I hope that made sense; The axle goes thru the inner race, so you are torquing between the end of the CV and the thrust washer |-| like that not ||-||. Words are sooo hard.
If it is too loose you might loose a wheel, if it's too tight it's the next guy's problem. I do notice that there is a burnishing on the inner collar of the old bearing.
Old Mar 1, 2012 | 06:53 PM
  #70
Here is Chiltons.
So, what part of "2006 HHR Service Manual" does not provide a reference?
