Speedometer Surges, and Wiring harness
Hi all,
was wondering if anyone can tell me if you have to purchase a new wiring harness or can you put a used one in from a wreckers?? Problem is i had the 0449 code and have replaced the gas cap, now i am wanting to replace the carbon filter and EVAP vent valve and was wondering if this has been a problem with anyone else?? The car surges and hesitates on take off from a stop, i was told it could be the wiring harness but,, from speaking with others they say it could be EVAP ..... please help... |
Welcome to the site, the P0449 code indicates a problem with the EVAP valve under the car near the fuel tank.
some aftermarket replacement valves required adapter harnesses and if a PO had replaced the valve there might be a patch harness back there. I recommend replacing the valve with a new one , AC Delco or Standard , watch out for offshore products from China sold on EBay or Amazon. https://cimg2.ibsrv.net/gimg/www.che...1723e661af.png a new wire harness isn’t usually required |
Thanks for the information, yes i plan on getting new parts for that EVAP problem.
But was wondering about the wiring harness if that can be purchased used ?? a mechanic told me that it may have to be replaced, or it could just be the outside connector plug for the wire harness..i dont want to go spend more money than i have to .. but i LOVE my HHR and want to do all i can to keep her fit and trustworthy. |
You can find a used wire harness, but it’s gonna be just as old as your’s
The "harness" in question is a short adapter that comes with the valve if you ask fort one for a 2006 HHR. GM changed the connector. As Oldblue said a previous owner may have3 already replaced the valve and the adapter might already be there.
What does this have to do with a surging speedo? |
With an evap leak you can throw a lot of parts at it for nothing. You could have a bad fitting line but try this. Pinch off the hose between the purge valve and the intake and see if it runs better.
the wiring harness is a surprisingly expensive item,
before getting rid of it, it may be advisable to "ring" it with a multimeter |
If you get a vent valve labelled "for 2006 HHR" you get the harness with it. The harness alone is available at parts stores.
This is what it looks like https://cimg1.ibsrv.net/gimg/www.che...11f7a22554.jpg |
That’s only required for the difference in the connector , cut the wires and solder in the connector to eliminate a loose connection. As we see in the screen shot I posted Dorman an Standard include the patch harness.
Originally Posted by donbrew
(Post 923342)
What does this have to do with a surging speedo? If it is the wiring harness that has to be replaced ... thats alot of money..(mechanic said.... over 1000.00).. for parts and labour ... im on a fixed income and if i can do the work myself i will ... but i dont have that kind of cash to put out ... |
| All times are GMT -5. The time now is 12:33 AM. |
