Hhr manual shift cable not available
Does anyone know where I could find a manual shift cable ? I have a 2009 hhr ss with a seized shift cable . GM no longer
has this part , part # 15939191. The car has been sitting In a transmission shop waiting to find a solution to the problem . It has been over a month now and still waiting to see if GM will make any more of these parts . Does not seem to be any after market part ? Please help I miss my SS😪 |
Welcome
If you can't find a new one, then maybe look for one in a wrecking yard. |
Welcome to the site, these guys claim to have one
https://www.tubmangmpartsdepot.ca/p/.../15939191.html |
[QUOTE=firemangeorge;873872]Welcome
If you can't find a new one, then maybe look for one in a wrecking yard.[/QUOT Thank you I have checked many wrecking yards inventory but so far No luck . I did find one in Fort Wayne but they told me someone cut the cable to get at something else . They also went on to tell me that the car was recently crushed ! if anyone knows of any at a wrecking yard I would be very grateful . |
Hi thanks , i have tried many of the GM part sites including the one you sent ( thanks much appreciated) only to wait several days after paying , only to find out the part is unavailable and refund my credit card . Seems these sites simply order from GM and get the same result . I spoke to a representative at GM parts giant and he checked the GM data base world wide and said there are none in stock anywhere ! My only hope is that the originsl supplier will be asked by GM to reproduce a number of these cables as I am sure Iam not the only one who needs this part .
Does this part only fit an HHR ?
Just the 3 years of SS 2.0 litre 5 speed turbocharged.
the Cobalts where different According to ZZP https://zzperformance.com/products/shifter-cables their part number for the Cobalt 2.0 SS will work with the LNF . https://www.tascaparts.com/oem-parts...cable-10383794 now I suggest calling ZZP or Tasca to see if this is myth or unicorn! If if it fits and works ! Unicorn! |
Finally some good news. I found out that GM
has several back orders for the hhr ss shift cable and will be making more sometime in October . The part should be available by mid November . I just have to drive my LT til then hope the winter weather holds off long enough so I can get one more ride in the SS this year . |
Originally Posted by KISMYSS
(Post 874247)
Originally Posted by EthanHHRSS
(Post 874349)
how did you obtain this information? i spoke with gm corporate directly and they even opened up a special case to investigate this issue , but the specialist that contacted me was absolutely worthless and had no idea on a course of action
