KPH Speedo
the odometer is 220 km .............where can i buy this odo .......manni /germany
I moved you to a new thread, Manni. So not to hijack that classified ad.
It looks like there are 2 part numbers for your SS. Both discontinued. 20819160 25897021 And SS Panel(probably the same?), also discontinued. 20758650 |
Unfortunately, the context is lost. What is the question?
If you want to display KPH instead of MPH you can change that in the personalization menu of the DIC. If you want a native KPH speedometer, you would need to get one from a junkyard in Canada or Maxico. They go higher. The odometer readings are stored in the BCM and a new instrument cluster must be installed with a computer like a Tech2 or SnapOn. |
He wants the 220 kilometre per hour speedo, from a Canadian SS. My LS only goes to 200 kph https://cimg8.ibsrv.net/gimg/www.che...e04acb5ba.jpeg See , 200 klms per hour! We don’t have hills that steep around here. |
