Commonly Used Part Numbers A place to post commonly used OEM part numbers needed for routine maintenance and replacement parts.
KPH Speedo
Old 09-01-2018, 08:03 AM
KPH Speedo
the odometer is 220 km .............where can i buy this odo .......manni /germany
butcherman is online now
Old 09-01-2018, 12:32 PM
I moved you to a new thread, Manni. So not to hijack that classified ad.
It looks like there are 2 part numbers for your SS. Both discontinued.
20819160
25897021
And SS Panel(probably the same?), also discontinued.
20758650
RJ_RS_SS_350 is offline
Old 09-01-2018, 02:22 PM
Technical Moderator
Unfortunately, the context is lost. What is the question?
If you want to display KPH instead of MPH you can change that in the personalization menu of the DIC.
If you want a native KPH speedometer, you would need to get one from a junkyard in Canada or Maxico. They go higher.
The odometer readings are stored in the BCM and a new instrument cluster must be installed with a computer like a Tech2 or SnapOn.
donbrew is offline
Old 09-01-2018, 02:27 PM
He wants the 220 kilometre per hour speedo, from a Canadian SS.
My LS only goes to 200 kph
See , 200 klms per hour! We don’t have hills that steep around here.
Oldblue is offline
Phobie11
11-20-2013 10:42 AM
wnyhhr
07-06-2013 02:18 PM
geg
07-30-2011 03:29 PM
SCOOT
2.4L Performance Tech
04-21-2006 07:32 AM
CNYMike
10-02-2005 12:17 PM
Quick Reply: KPH Speedo
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
