Commonly Used Part Numbers A place to post commonly used OEM part numbers needed for routine maintenance and replacement parts.
Part Numbers for elusive and common parts - Broken into separate posts in this thread
Old Dec 10, 2013 | 12:52 AM
There have been quite a number of posts regarding part numbers for various repairs or enhancements - here's a thread cataloguing some of the parts:
Note: we are going to try and keep this thread short, so once stuff is migrated into the first post, we'll likely delete the info posting.
PLEASE NOTE: To the best of our knowledge the part numbers here were current as of the date they were posted. Be aware that they may have changed or the parts may have been superseded with updated/modified parts that have different part numbers. So always double check with your supplier.
Also - it is quite impractical to list all the part numbers for the various manufacturers, so we will list what we can. Posting a specific manufacturer's part number is not a recommendation on that specific part - other manufacturers parts can likely be substituted to everyones satisfaction. In other words, not including the part numbers from another manufacturer is not a reflection of the quality or suitability of parts they may have available.
Where do you go to find the parts you ask - well of course there is your local Chevy dealer, but you can also try eBay, Amazon.com, and also your local autoparts store, or just do a search of the internet using the part number on Google or your favorite internet search engine. Often a "google search" will also list out some Youtube videos on how to remove and reinstall or fix the part - such as replacing the brakes etc.
It also seems Dorman and Duralast use the same part numbers - but do a double check before assuming so.
For GM parts this link may be handy - Find OEM Chevrolet HHR Parts.
GENERAL MAINTENANCE:
Spark plugs:
2.2L/2.4L - AC Delco part number 41-103 (iridium)
2.0L Turbo - AC Delco part number 41-108 (iridium)
Spark Plug (Coil-On-Plug) Boots:- courtesy Budzone
2.2L/2.4L & 2.0L - set of 4 - rock Auto - P/N 6714298
Oil Filter - AC Delco - PF457G
Air Filter (2.2L/2.4L) - AC Delco - A3054CF - GM P/N 19254692
(2.0L) - ACDelco #A3099C - GM P/N 20774655, Purolator - A16065, Wix - 49459
Air Filter Box mounting Grommet - GM calls it an "Insulator"
- P/N - 12563914 (2.2L/2.4L)
- P/N - 25920906 (2.0L)
Cabin filter
- AC Delco P/N - CF125
- GM P/N - 52493319
- Duralast P/N - CAF1797DL
- CARQUEST P/N - 89882
- K&N - VF2006
Serpentine Belt
- 2.2L/2.4L 2006-07 - Dayco 5050400 (40" - later 07's have 40.5")
- 2.2L/2.4L 2008-11 - GM 24466972 / Dayco 5050405 (40.5")
Light Bulbs - suggested by 843de
- Headlamp Light Bulb Size: H13 (9008)
- Parking/Front Turn Signal Light Bulb Size: 3157LL
- Rear Turn Signal/Tail Light/Stop Light Bulb Size: 3057LL
- High Mount Stop Light Bulb Size: 921
- Fog/Driving Light Bulb Size: 9140 (non-SS) - H11 (SS model)
- License Plate Light Bulb Size: 168
- Back Up Light Bulb Size: 921
- Front Side Marker Light Bulb Size: 194
- Rear Side Marker Light Bulb Size: 194
- Map Light Bulb Size: 2825LL
- Dome Light Bulb Size: 562
- Trunk/Cargo Area Light Bulb Size: PC168
Battery - suggested by 843de
- ACDelco Professional Silver - Battery pn 90PS (2006-2011) 600 CCA
- Super Start® Extreme - Battery pn 90EXT (2006-2011) 600 CCA
- Super Start® Premium - Battery pn 90PRM (2006-2011) 590 CCA
- Duralast Gold/Battery pn 90-DLG (2006-2011) 600 CCA
- Duralast/Battery pn 47-90-DL (2006-2011) 600 CCA
- AutoCraft Gold Battery pn 90/T5 (2006-2011) 650 CCA
- NAPA Legend International pn 7590 (2006-2011) 600 CCA
* Battery Vent Tube Kit GM pn 15247277
>> Note: T5 is the NEW DIN designation for the OLD Group 90 as noted by donbrew
Fuel Door - popper spring GM p/n 20912532
Switches
- Hazard Indicator - GM P/N: 20934801 - fits (2006-2011) - suggested by 843de
- Circulating fan switch ACDelco 15-5691 (says it does not fit, it does)
Old Feb 21, 2014 | 03:17 AM
Part Numbers for elusive and common parts - Part II
~~~~~due to limit on number of characters per posting, the first post has had to be split into several parts~~~~~
INTERIOR:
Brake Pedal PAD
- GM part # 22729032 - Automatic (MN5)
- GM part # 22729033 - Manual Trans (M86, MU3)
Clutch Pedal Pad
- GM part # 22729033 - Manual trans only (M86, MU3) :)
Door Bumpers for Upper Dash Storage Compartment Door: - (Yup, those little rubber thingies) - as noted by Chevymgr
- GM PART # 19180975
Ignition Switch - Revised (Ref Recall #14063) 2006-2007 HHR - as noted by 843de
- GM P/N - 23215459 Note: availability late April 2014
Interior Door Handles - as noted by stepsider
-GM PN 19299614 (left-handed) PN19299613 (right -handed)
-Dorman part #80369 (left side) - part #80370 (right side)
Door Latch/Lock assemblies - as noted by 843de
- Latch/Lock/Actuator Front Side Door L/H GM pn 20791792 (2006-2011)
- Latch/Lock/Actuator Front Side Door R/H GM pn 20791793 (2006-2011)
- Latch/Lock/Actuator Rear Side Door L/H GM pn 20791794 (2006-2011) Wagon
- Latch/Lock/Actuator Rear Side Door R/H GM pn 20791795 (2006-2011) Wagon
- Latch/Lock/Actuator Rear Side Door L/H GM pn 25811543 (2007-2011) Panel
- Latch/Lock/Actuator Rear Side Door R/H GM pn 25811544 (2007-2011) Panel
Door Check Link- FRONT - GM p/n 25800726
REAR - GM p/n 25875215
Rubber Liner for Door Grips - they hide the screws at the bottom of the door panel grips: (suggested by 843de)
- LINER - Front & Rear Side Door Trim Finish - GM P/N: 15146916 (Fits 2006-2008)
- LINER - Front & Rear Side Door Trim Finish - GM P/N: 25874249 (Fits 2009-2011)
- LINER - Floor Console - Cup Holder - GM P/N: 10377297 (Fits 2006-2008)
- LINER - Floor Console - Shifter tray - GM P/N: 15844090 (in front of shifter)
Compartment, Dashboard, Top - as noted by 843de
- Part #20777101 For Ebony dashboards.
- Part #20777102 For Cashmere dashboards.
- Part #20777103 For Gray dashboards.
>> GM list price is $123.71 each.
Rear Hatch Gas Struts - suggested by Snoopy
- Sachs - P/N: SG330082 (supplier to GM I'm told and half the price of OEM's)
Rear Cargo carpet for 4-door - GM P/N: 17803396
Rear Cargo all-weather mat for panel (includes rear seat mat) - GM P/N: 25795311
Load Floor/Cargo Shelf, Removable. (2006-2011) - as noted by 843de
- GM P/N: 20879841 - Grey
- GM P/N: 20879842 - Ebony
- GM P/N: 20879843 - Cashmere
Pedal Assembly, Accelerator, (2006-2011 Incl SS) - as noted by 843de
- GM P/N: 20757615 - Includes Position Sensor & Bracket
Seat Belt Stop Kit - Dorman P/N: 74357 at Advance Auto Parts as noted by Cat Man HHR
Shifter Assembly - upgraded 2009 SS part (including shift handle and shifting mechanism and retrofittable to 2006 LT/LS etc - see install guides in How-to Section) - GM P/N: 25860318 (rumoured to be replaced with a newer P/N such as 25995461, so check with dealer or GM parts supplier first)
Sunshade, Windshield Visor - 2006-2011 - as noted by 843de
- GM P/N: 25788231 - LHD visor
- GM P/N: 25788230 - RHD visor
Window Switches
Master Drivers Window Switch (ie: for 09 LS)
- ACDelco#D1954F/GM 20945129 (green illumination)
(ORIGINAL - GM 25951693)
Front Passenger Window Switch - GM 22895545 (green illumination)
(ORIGINAL - GM 25877776)
Rear Left and Right Window Switches: GM 22895546 (non illuminated)
or GM 22895545 (green illumination that wont be functional due to the missing yellow power wire from the headlight switch)
(ORIGINAL - GM 25877777)
EXTERIOR:
Fuel Door Popper - Spring - as noted by Lucky and ZTony8
GM P/N - 20912532 - (note in the catalog that says to seal all the voids in the plunger housing with flexible sealer prior to installation of the spring)
Mud Flaps - -as noted by Silverfox
- Front (pair) - GM P/N - 12499526
- Rear (pair) - GM P/N - 12499527
- Full set (front and rear) - GM P/N - 12499528
Rear Door Paint Protection Film - -as noted by 843de
- Left rear door - GM P/N - 25791044
- Right rear door - GM P/N - 25791042
Rear Hatch Weather Stripping - -as noted by Lucky
GM Parts Direct p/n: 15862172 (~$70)
Headlights - as noted by 843de
- Capsule, Headlamp, LH GM P/N - 15827441 (2006-2011)
- Capsule, Headlamp, RH GM P/N - 15827442 (2006-2011)
Headlamp support brackets...(Support, Bumper, Fascia) in GM-ese. - as noted by 843de
- GM P/N 15836388 is for the Right side.
- GM P/N 15836387 is for the Left side.
.... GM list is $14.15 each
Fascia to Front Fender bracket, plastic mounting bracket - (GM calls it a side bracket) - As suggested by Lucky
- Left side - GM P/N - 15827749
- Right side - GM P/N - 15827750
  • Driver Side Front Bumper Fascia Bracket
    • GM GENUINE #15827789
  • Passenger Side Front Bumper Fascia Bracket
    • GM GENUINE #15827790
Grille Insert Screen - Front - Lower - As suggested by Oldblue
- GM 25829960 Grille Insert Screen, Front - protects AC condenser
Splash Guards - As suggested by Oldblue
- GM # 12499528 - Front & Rear Molded Set - Black with HHR Logo
Old Jul 2, 2014 | 09:28 PM
HVAC - suggested by paulBvtn
Air Vents on Dash - movable/adjustable -
- center vent Left side - PN 20933882
- center vent Right side- PN 20933883
..(GM list price is $29.57 each)
- outer vents Left side - PN 20933884
- outer Right side - PN 20933885
..(GM list price is also $29.57 each)
Blend Door Actuator - GM PN 10393075
Blower - Cabin Fan
- Autozone - P/N: 75778
- GM HVAC Blower Motor Kit GM P/N: 25776197 Supersedes to 1581101 (2006-2011) - suggested by 843de
HVAC Control (head unit) - (2006-2011)
GM P/N 22745744 w/RPO KA1 (heated seats) (14l GRAY)
GM P/N 22745745 w/RPO KA1 (heated seats) (19l EBONY?)
GM P/N 22745746 w/o RPO KA1 (14l GRAY)
GM P/N 22745747 w/o RPO KA1 (19l EBONY?)
Resistor for fan motor
- GM - p/n: 158189-10 (aka 15818910)
- Autozone - p/n: DR752
Water Deflector/Butyl Patch - for 2006 and early 2007's
- GM P/N: 25785783 (2006 & Early Production 2007) - suggested by 843de
Windshield Wiper Transmission - GM pn 15793206 - suggested by Oldblue
Wiper mechanism repair - - suggested by donbrew/jeanvaugeois
- DORMAN P/N: 49447 (wiper linkage bushing assortment)
Windshield Washer Fluid Container - under hood
GM p/n 15147046 Kit, (2006-2011) All Models
Windshield Washer Pump Kit - (2006-2011 All Models)
- GM P/N: 10355743
Windshield Wipers -
- GM P/N: 23353587 Per Silverfox
COOLING SYSTEM -
4-Cyl. 2.4 L - 2006 - suggested by FiremanGeorge
* the following are GATES part numbers and may differ for other years
- Serpentine Belt .................................................. ... GK050400
- Tensioner Assy. .................................................. ........ 38177
- Tensioner Pulley .................................................. ....... 36193
- Upper Radiator Hose - Front ......................................... 23163
- Upper Radiator Hose - Rear; (1 1/4" x 3") ...................... 24020
- Lower Radiator Hose - Front; 1st Design ......................... 21942
- Lower Radiator Hose - Rear; 1st Design .......................... 23162
- Lower Radiator Hose - Rear; 2nd Design ......................... 23164
- Heater To Thermostat Hose ........................................... 19848
- Tee To Oil Cooler Hose; 1st Design ................................. 19847
- Oil Cooler To Thermostat Hose ....................................... 28475
- Filler Pipe To Rad. Hose; (3/8" x 20") .............................. 28409
- Thermostat To Heater Hose ............................................ 19478
Thermostat - (2006-2011 All Models)
ACDelco 131-158 GM P/N 12622410
Oil cooler O-rings - GM P/N 12601371 and 12601372
FUEL SYSTEM -
- Fuel Pump AC Delco M10015 from Rock auto (2.2 & 2.4L only) - courtesy of Budzone
Old Dec 9, 2015 | 11:15 AM
ENGINE REPAIR:
Airbox/Filter housing parts - suggested by FMHHR
- REAR AIRBOX BRACKET - GM P/N - 15784193
- AIRBOX MOUNTNG GROMMETS - GM P/N - 12563914
Air Temp Sensor - Outside - suggested by alexrckid
- Advance Auto BWD p/n WT3091 (located in the right front fender)
Camshaft Position Actuator Solenoid Valve
** GM P/N - From oldest to newest p/n as of March 2013:
--- Intake 12628347 = 12646783 = 12655420 = 12679099
--- Exhaust 12628348 = 12646784 = 12655421 = 12679100
-DORMAN #917-216 for exhaust and #917-215 for intake
Cam sprocket bolts GM 11588844 - suggested by donbrew
EVAP Canister Vent Valve (near the gas tank) - suggested by Donbrew
- GM P/N - 214-234 (Available on Ebay (and online GM stores) for around $18, but has the new style connector for 2010-2011.
- Harness adapter - ACDelco P/N - 19257603 - about $18 - for earlier models and is what makes them around $50 at the parts stores
Grommet for canister-Dorman 65113
Harmonic Balancer Bolt GM 11589123 - suggested by donbrew
INTAKE DUCT - 2.2L/2.4L (2006-2011) - suggested by Oldblue
- GM P/N: 15865168 - many here refer to it as the "wooly worm"
2.0 (2008-2010) GM P/N 15909460
Mass Airflow Sensor [MAF] 2.2L/2.4L (2006-2011) + 2.0L Turbo (2008-2010) - suggested by 843de
- GM P/N: 15865791
- AC Delco P/N: 213-4222
Pedal Travel Sensor (accelerator position sensor assembly) - 2009-11 - suggested by Lucky
- GM P/N: 25902025 (Dealer was only 4.00 more than aftermarket)
EVAP Purge Valve v -(under the hood) PV443 (Duralast/AutoZone) - suggested by donbrew (The Duralast parts are IDENTICAL to OE down to the mold marks for about 1/8 the price)
EVAP Vent Valve - (next to gas tank) PV483 (Duralast/AutoZone) - suggested by donbrew (The Duralast parts are IDENTICAL to OE down to the mold marks for about 1/8 the price)
Timing Chain Tensioner - suggested by alexrckid
- AC DELCO (new type) p/n 12608580
Valve Cover Gasket - 2.4L - - suggested by Lucky
- GM p/n: 12598014
2.2L engine part numbers - - suggested by donbrew
http://parts.nalleygmc.com/showAssem...roduct=2670539
2.4 and 2.0 - Search Chevrolet Parts and select "Show All Models" under Models on left side etc.
SUSPENSION/STEERING/BRAKES/TPMS:
AXLES - SS Automatic -- suggested by jojothetattooboy
- GM has discontinued 15938134 - for the front axles on the 2008, 2009 and 2010 HHR SS models with the automatic transmission
- a stage 2 axle is available via The Driveshaft Shop | Home page - part number RA5107L2 (2008-2010 HHR Turbo/Automatic Level 2 Front Axle) - jojothetattooboy ordered the first set (waiting to hear how they fit/work out)
BRAKE PADS - - suggested by RJ_RS_SS_350
SS - J56(Heavy Duty SS Brembo)
- Front GM Pads P/N 25808929 AC Delco 171-1012
- Rear Pads GM P/N 10365723 AC Delco 171-0865
LS/LT - Front Pads - GM - 25809846
- Rear shoes (2006-2008) - GM - 19256491 (2009-2011) -GM - 25960262 (mid year change, some 2009 have the older)
BREMBO Brake Upgrade -- suggested by paulBvtn on behalf of LT1GMC
- Brake Line: The proper Brembo spec brake line is 1.5" longer, with a 1.5" longer "insulator" on it. The longer line is not near as stretched tight at full turn. GM P/N: 25954272, about $25 each, and come with new banjo nut and copper washers
Coil Springs - REAR
Autozone - pn: CC81065 is specified for the SS rear coils
and - pn: CC81063 for non-SS
Jounce Bumper for rear springs - F1/F3 (not sure about F5)- suggested by Donbrew on behalf of Firemangeorge
GM Part Number: 25993737 - MSRP $56.62 - Online Price $33.56
HUBS -- suggested by 843de
--> * Note: see "Hub axle nut" below
- Front hub/bearing assembly FE-1/FE-3 2006-2007 Non-ABS. Use GM PN 22728987
- TIMKEN PN HA590087 - Duralast by Autozone PN DL513237 2006-2008 (suggested by Twistedtat)
- Front hub/bearing assembly FE-1/FE-3 2006-2011 ABS Equipped. Use GM PN 22715554
- Front hub/bearing assembly FE-5(SS) 2008-2010. Use GM PN 15793213
- Rear hub/bearing assembly FE-1/FE-3 2006-2007 Non-ABS. Use GM PN 15889807
- Rear hub/bearing assembly FE-1/FE-3 2006-2011 ABS Equipped. Use GM PN 15889806
- Rear hub/bearing assembly FE-5(SS) 2008-2010. Use GM PN 15798483
Hub axle nut - for FE1 and FE3 only - Use GM PN10289657 - NOTE: GM specifies they must be replaced, and not reused.
Lower Control Arm rear bolt ALL HHRs GM P/N 11589009
Lower Control Arm - NON-SS models - only for FE1 and FE3 suspensions
- GM P/N - 15787555 - (includes lower ball joint and both bushings installed) - Right side - passenger side
- GM P/N - 15787556 - (includes lower ball joint and both bushings installed) - Left side - drivers side
- Duralast (autozone)/Dorman P/N - 521-025 - (includes lower ball joint and both bushings installed) - Drivers side
- Duralast (autozone)/Dorman P/N - 521-026 - (includes lower ball joint and both - bushings installed) - Passenger side
- Rockauto - lower control arms part # RK620897 & RK620898 - they have several suppliers of these arms complete with bushings and ball joint - so check via a search for vehicle parts.
***NOTE: some stores/suppliers list LCA's for the HHRs and Cobalts - and are made of stamped steel - NOT aluminum as per the stock ones - we cannot recommend the stamped steel ones for various reasons, so don't even ask
Lower Control Arm - SS models ONLY (FE5 suspension)
IMPORTANT: they are only available thru GM - No after-market suppliers make a compatible part at this time, even though they may say the parts they have are for all HHR's
- GM - P/N: 25930724 - Right
- GM - P/N: 25930725 - Left
(note: Do NOT substitute a FE1 or FE3 LCA - the ball joint stub on them is 20MM and is not compatible with the spindle on a FE5/SS which is 20.5MM)
Lower Control Arm Rebuild Parts
- Duralast Rear Bushing (autozone) P/N - FB782 (2.37" or 60.2mm outer diameter)
- MOOG "problem solver" Rear Bushing - K200792 - also K201285 which is zinc coated for use in aluminium LCAs
- MOOG Ball Joint - K80567 (require drilling out old one and bolting this in - FE1/3 ONLY - does NOT fit FE5)
- MOOG front LCA bushings - K200361
STRUTS
FE5 Suspension (SS):
- GM: P/N 19179738 (right side) - P/N 20794824 (left side) - (from member andyb)
- AC DELCO: 506667 (right-side) - P/N 560581 (left side) - (from member sinabu)
Sway Bar Bushings - suggested by Snoopy with addons from 843de
- FE1:
>>> 2006 production until VIN#3GNDA23P26S546471. Use GM PN 15822993 (which equates to a 23mm bar - energy suspension pn: 9.5159 (greaseable) - 9.5115 (non-greaseable))
>>> for FE-1 suspension after VIN#3GNDA23P26S546472. Use GM PN 20902784
(Note: my early early 2006 FE1 sway bar crudely measures out at 23MM so double check yours as the 1" bushings do not fit mine)
- FE3: Energy suspension poly for 1inch bar - greaseable - p/n 9.5161 (9.5110 non-greaseable) -
These are a little more than 25 mm and can clunk, we recommend OEM bushings for a quiet ride.
OEM GM part number 20902784 (GM calls them Isolators)
- FE5: Energy suspension poly for 23mm bar - greaseable - p/n 9.5159 (9.5115 non greaseable)
------- GM - 20902785
STEERING - INTERMEDIATE SHAFT KIT - courtesy of Oldblue
- GM - 25834100 - 3 piece shaft kit, including the two universals LS/LT ONLY
- GM - 25943354 - SS GM has DISCONTINUED THIS PART!
SWAY BAR END LINKS - suggested by Snoopy
- Moog K750012 (9.86" center to center)
- NAPA 265-1833 (9.86" center to center)
- RAYBESTOS 5451624 (281mm)
- GM P/N 20784688 or 20784687 (250mm center to center)
TIE ROD - inner - suggested by Lucky
- installed the AC DELCO ones on a 2008 -
- AC DELCO #45A2206
- GM #19261965.
TIRE PRESSURE MONITORING SYSTEM - TPMS - suggested by 843de
- TPMS Sensor W/Bolt in Valve Stem GM P/N - 15268606 (2008-2011)
- TPMS Sensor W/Rubber Valve Stem GM P/N - 25920615 (2008-2011)
Wheel Nuts - suggested by Sleeper
thread pitch & length= 12mm x 1.5 - 60 deg. taper for the stock wheels (taper for aftermarket wheels may vary and are not compatible)
Last edited by Oldblue; Aug 3, 2023 at 05:23 AM. Reason: Sway bar VIN is 2006, so edited out 2007 reference
Old Jan 22, 2019 | 09:19 PM
FWIW: That part # for TPMS sensor w/rubber valve stem is Obsolete.
Old Mar 31, 2019 | 11:06 AM
DrLoch's Avatar
Camshaft Position Actuator Solenoid Valve P/N is obsolete as well.
Can we add timing chain information as well?
Old Mar 31, 2019 | 11:24 AM
Updated! And here is the Timing chain information
https://www.chevyhhr.net/forums/how-...in-kits-60394/
Old Apr 3, 2019 | 09:56 AM
Dorman 917954 Timing Chain Guide Bolt, is now available
Old Apr 10, 2019 | 04:37 PM
cloudhome's Avatar
Note: Moog K200361 horizontal bushings sold today DO NOT fit aluminum lower control arms.
Old Apr 10, 2019 | 05:37 PM
That is the only part number I can find for the application. What have you found?
Others have used it.
