Originally Posted by 2005HHRauto
(Post 805065)
Not true...:skull1:
Originally Posted by donbrew
(Post 805084)
He says they are installed and working.
The axle spindle nut size is how you know if you have the right one...:twothumbs: 36mm = HHR SS 30mm = HHR LS LT |
Found these axle part numbers today,
W0133-1775149 For auto trans W0133-1835283 For manual Autopartswarehouse, CarID, and autopartsway.ca all like these numbers, but Amazon does not. |
Good find Randy
Should make this a sticky. Just for laugh's took the auto p/n and I found this on Wally World https://www.walmart.com/ip/First-Equ...22227055879817 |
Originally Posted by Cat Man HHR
(Post 821394)
Good find Randy
Should make this a sticky. Just for laugh's took the auto p/n and I found this on Wally World https://www.walmart.com/ip/First-Equ...22227055879817 EDIT: This is a little troubling, for manual trans: GM says right and left are different. Left 20778307 Right 20778308 DRIVE SHAFT/FRONT WHEEL I wonder why all the aftermarket only give one number, not side-specific. |
Cause their incorrect!?
Probably. Either that or the difference in length is negligible. Hmmm... not sure I've ever used that word before.
The difference is a good 3 inches. Auto have the same because they have an internal extension on one side.
I had thought the difference in the LT and the SS shafts was the number of splines? |
The GM part numbers, on Amazon, says they fit. Also there is a review on each, from the same buyer, that they fit. Amazon shows a difference in length of 6.5"!! Granted, that isn't precise, but shows that they are indeed different lengths, like don said.
So either W0133-1835283 doesn't fit at all, or it's only for one side, and we don't know which. So we're back to GM only again. Might call into question the accuracy of the fitment for the auto axles as well. If anyone orders, get a fitment guarantee from the seller! |
Business as usual, GM only, or get your old ones rebuilt, your SS will be down for a spell
| All times are GMT -5. The time now is 06:29 AM. |
