Commonly Used Part Numbers A place to post commonly used OEM part numbers needed for routine maintenance and replacement parts.
SS axles+brake calipers+fuel pump
Old Jun 8, 2016 | 12:02 PM
Originally Posted by 2005HHRauto
Not true...
He says they are installed and working.
Old Jun 8, 2016 | 03:03 PM
2005HHRauto's Avatar
Maybe he doesn't have an HHR SS
The axle spindle nut size is how you know if you have the right one...
36mm = HHR SS
30mm = HHR LS LT
Old Mar 24, 2017 | 12:36 PM
Found these axle part numbers today,
W0133-1775149 For auto trans
W0133-1835283 For manual
Autopartswarehouse, CarID, and autopartsway.ca all like these numbers, but Amazon does not.
Old Mar 24, 2017 | 02:07 PM
Cat Man HHR's Avatar
Good find Randy
Should make this a sticky.
Just for laugh's took the auto p/n and I found this on Wally World
https://www.walmart.com/ip/First-Equ...22227055879817
Old Mar 24, 2017 | 03:07 PM
Originally Posted by Cat Man HHR
Good find Randy
Walmart, sold by autopartsway. As always, do your own search and order from whoever you want. Partsgeek likes these numbers also. We might have a winner here.
EDIT: This is a little troubling, for manual trans: GM says right and left are different.
Left 20778307
Right 20778308
DRIVE SHAFT/FRONT WHEEL
I wonder why all the aftermarket only give one number, not side-specific.
Old Mar 24, 2017 | 04:45 PM
Cause their incorrect!?
Old Mar 24, 2017 | 04:51 PM
Probably. Either that or the difference in length is negligible. Hmmm... not sure I've ever used that word before.
Old Mar 24, 2017 | 08:57 PM
The difference is a good 3 inches. Auto have the same because they have an internal extension on one side.
I had thought the difference in the LT and the SS shafts was the number of splines?
Old Mar 24, 2017 | 09:31 PM
The GM part numbers, on Amazon, says they fit. Also there is a review on each, from the same buyer, that they fit. Amazon shows a difference in length of 6.5"!! Granted, that isn't precise, but shows that they are indeed different lengths, like don said.
So either W0133-1835283 doesn't fit at all, or it's only for one side, and we don't know which. So we're back to GM only again.
Might call into question the accuracy of the fitment for the auto axles as well. If anyone orders, get a fitment guarantee from the seller!
Old Mar 24, 2017 | 10:17 PM
Business as usual, GM only, or get your old ones rebuilt, your SS will be down for a spell
