Chevy HHR Network
-   Commonly Used Part Numbers (https://www.chevyhhr.net/forums/commonly-used-part-numbers-68/)
-   -   Windshield Washer Fluid Pump (https://www.chevyhhr.net/forums/commonly-used-part-numbers-68/windshield-washer-fluid-pump-60214/)
UWZerokoolX 04-14-2018 03:51 PM
Okay, I cannot justify buying an entirely new forty dollar Windshield Washer Pump just for the rubber gromet that seals it to the windshield washer resvoir. Does anyone have a part number for the rubber gromet?
Oldblue 04-14-2018 04:03 PM
Read post number 8, while this may or may not correct your issue , hey it’s inexpensive and may save you a few bucks.
https://www.chevyhhr.net/forums/main...eak-fix-54278/
donbrew 04-14-2018 04:03 PM
Usually it is the internal seal that fails, especially in freezing weather, that looks like the grommet is leaking.
You would probably have to go to a store that has jobber boxes to match one up. Bad news is not all new pumps come with a new gasket.
They can be had for closer to $30. https://www.ebay.com/itm/ACDelco-193...tWqOzJ&vxp=mtr
UWZerokoolX 04-14-2018 04:08 PM
Originally Posted by Oldblue (Post 842244)
Read post number 8, while this may or may not correct your issue , hey itís inexpensive and may save you a few bucks.
Yeah I just got done reading that blue. :( I was hoping that someone would come up with a part number by now.
And don't you worry don, I am not going to wig out on you. :roflol:
I might as well do the simple cheap fix... I already have my air intake hose duct taped because I cant find the part number for that either. -_- *Deskface* argh!
donbrew 04-14-2018 04:16 PM
You might try
a. looking in the part number thread
b. looking at an online GM parts store like this: https://www.gmpartsgiant.com/parts-l...ke-system.html
Oldblue 04-14-2018 04:17 PM
Air intake duct hose, commonly called the Woolley Worm.
One solution
https://www.chevyhhr.net/forums/prob...problem-53013/
Wolley worm part number in post #9 here
https://www.chevyhhr.net/forums/main...cleaner-58572/
RJ_RS_SS_350 04-14-2018 04:21 PM
https://www.chevyhhr.net/forums/comm...33/
4silverado 04-20-2018 02:01 PM
I don't know if this helps, but I picked up a 2011 back in January. It would dump washer fluid on the ground faster than you could dump it in. I removed the reservoir thinking that it might be cracked; the pump grommet was bad. I wiped everything down and applied a liberal amount of blue silicone and put everything back together. I waited a full week before adding fluid. So far, it's holding fluid with no issues.
© 2019 MH Sub I, LLC dba Internet Brands
